TInmania wrote:
GordonThree wrote:
Once I ran out of the pressed wax fire-starters, so I made my own. I always have a huge supply of plastic grocery bags for cleaning up after my dog, so I grab a few unused bags and a few sheets of paper towel. Twist them tightly together into a log like shape. Sit in the fire pit, stack some kindling and logs loosely around it and light. Usually works good unless the pit and wood are soaked... then its time for lighter fluid to dry things out a bit :)
Did I read this correctly that you are burning plastic bags along with paper towel?
Mike
Yes, two plastic bags, two sheets of paper towel. What do you think makes match light charcoal or pressed fire starters work, hint; it's not magic.
