covered_wagon
Nov 16, 2014Explorer
Your water heater will last longer if you flush the sediment out about once a year. Some of the hose bibs on the bottom are plastic and can snap. I changed over to a brass hose bib.
The second thing is when you flush it each year, making it last longer, the plastic dip tube can go bad so you have to be ready with an extra one handy. The dip tube holder is simply a plumbing nipple on top of the water heater, on the inlet side, just sleeved inside. Some have water inhibitors that are in the way of the new dip tube so you have to buy the same sized threaded nipple is all to sleeve the new dip tube into. Pretty simple really.
About Around The Campfire
45 PostsLatest Activity: Aug 01, 2026
