navegator
Nov 12, 2020Explorer
Bees with an attitude
Africanized honey bees are very aggressive in defending the hive, to them it does not matter if the threat is two legged or four legged.
When the bees establish a hive, they also establish boundaries of defense, and knowing the subtle warnings can save you from a nasty sting or several more.
When entering the defensive perimeter, the bees will begin to "harass" you by flying directly to your face and veering off at the last minute, bees have very good eye site and recognize the face or head of the threat, one or two bees you are in the outer perimeter, the closer you get to the hive the more bees will come warning you until they sound the alarm and you're done, you need to run at least a mile or more before they they stop chasing you, that is if you can out run then.
And jumping into a pool will not save you they can see you under the water if it is a clear swimming pool and every time you come up for air they will enter your mouth and nose, one person in Arizona perished with more than a thousand stings in his mouth, throat and trachea.
If you are walking along and the bees start coming at you, you are now close to a bee hive, it can be anywhere on a tree, on a building and even underground, another thing that annoys them is noise specially low rumbling or thumping repetitive, lawnmowers and Diesel engines as example.
When the bees start coming at you best thing is to turn around and leave the area, also alert the proper authorities so that they can move the hive to a safe place, killing them is not productive since we need them for agriculture.
If there is a bee in your immediate vicinity do not swat at it, gently move away or very slowly move your had towards it as long as it is not coming at your face and veering off, it will get the message that it is not welcome there.
So BEE alert for bees coming at you.
navegator
navegator
