- EsoxLuciusExplorerHell, one year I ran into 12 inches of snow in OKC on I-35. I'd take the most direct route with an eye on the weather.
- 2gypsies1Explorer IIII'd recommend the southernmost route even if it's longer. Monitor the weather as you're traveling and be prepared to make changes. Any of the 3 routes mentioned 'can' be hazardous in winter. You just never know until you start to head out. Be Flexible!
- runner_oneExplorer
Thom02099 wrote:
can get iffy in the winter
That is what I was referring to. Although all those routes are good roads. Pulling a trailer through some of those passes in winter conditions could try the skill of inexperienced tow drivers.
You have to admit that even an interstate can get dodgy for towing in winter. - Thom02099Explorer II
rlyons wrote:
I'm looking for the best winter route for pulling a travel trailer from Lincoln NB through to Mesa AZ. I will be trying to watch the weather as I travel from Winnipeg, MB straight South to NB but am not sure which is the best route from Lincoln NB to Mesa for winter weather and road conditions.
"Best" is always subjective, depending on what criteria is important to you. "Best" to avoid weather issues would likely be the 3rd one suggested above. "Best" for making good time and getting there quickly, may be the 1st one suggested.
Not sure what elevations/steepness he was referring to, as the highest point would be Raton Pass at ~7600 feet. It's a bit of a climb and decline, and can get iffy in the winter, but it's well maintained, and is a major N/S route. Once into NM, I don't recall anything that would remotely be considered a challenge for steepness on the route proposed, staying on I-25 to I-40. It is, however, pretty open and subject to the whims of nature. If you're a weather watcher, you'll likely know what is the best route when you actually get ready to leave. - TyroneandGladysExplorer
runner_one wrote:
Well if you just google it you get this route.
What you dont see here is that there is some pretty high altitudes and steep grades along the section between La Junta, CO and Albuquerque. I know, I have driven it. So I think I would avoid that.
This, might be a good second choice, there are few steep hills and curves on that route. I have driven most of it too. But the section between Holbrook and Mesa can be dodgy in winter.
But if you are really concerned about weather and possible snow problems This would be the absolute best route to avoid snow and steep roads.
If I was worried about driving in bad weather at all this would be the route I would take, plus, you get to see more of the country.
The only thing I would add would be weather permitting go to his first Google map link and choose the US 54 W and I-40 option. Should be a four to five day trip and check the 5 day weather forecasts along the route. In New Mexico overnight at Tucumcari and again in Gallup - TyroneandGladysExplorerOOPS
- 1492ModeratorMoved from Forum Technical Support
- mike-sExplorer IIOh, no! Google maps is broken!!!!
- runner_oneExplorerWell if you just google it you get this route.
About Bucket List Trips
13,488 PostsLatest Activity: Jan 17, 2025
