- 1jeepExplorer IIthanks for all the info, I also spoke to a friend last night that did va and he confirmed going 13 via tunnel bridge was nice.
- CrabbypattyExplorerIf by chance your going down then. We did it twice lots of fun.
http://www.chincoteaguechamber.com/pony-swim/pony-swim-day - darsben1ExplorerNo I have done the tunnel/bridge and enjoy i. Just be aware of the weather and if it is going to be windy then choose an alternate route
- kerrlakeRooExplorer
1jeep wrote:
so would you suggest continuing down 95 past Washington? I get the propane thing, someone already told me to make sure they are shut off prior to getting to the tunnel.
No when you cross the Delaware Memorial Bridge, follow the signs for Rt 13 South. - K_CharlesExplorerI like the bridge tunnel. The Delmar peninsula is a nice drive.
- 1jeepExplorer IIso would you suggest continuing down 95 past Washington? I get the propane thing, someone already told me to make sure they are shut off prior to getting to the tunnel.
- darsben1ExplorerPropane must be off
Not more than two non-permanently mounted containers having maximum individual capacity of 105 pounds water capacity or 45 pounds LP-Gas each, or one container having maximum capacity of 60 pounds LP-Gas, or (b) not more than two permanently mounted containers having maximum total capacity of 200 gallons water capacity LP-Gas when used as a motor fuel. Tanks must meet the approved standards of the Department of Transportation and are subject to inspection at toll plaza. They must be properly secured and valves closed while crossing the facility.
And if the winds are over about 40-45 MPH you will not be allowed across
About Bucket List Trips
13,487 PostsLatest Activity: Jan 18, 2025
