- VeebyesExplorer IICan't imagine needing 50amps in the mountains. Simple awareness of what is turned on should keep power needs well under 30amp. Knowing what is on which circuit leg within coach or trailer helps too.
- docjExplorer
obgraham wrote:
Run your Keurig, Washer, dryer, hair dryer, curler, and several TV's and pretty soon you're needing 50 amps!
Some things like hair dryers and coffee makers are high current items but are only used for short periods of time. Modern TV's use only a couple of hundred of watts. We've converted all our 120V lighting to LED's so we don't draw more than 100W for all of it. As full-timers sometimes we get 30A sites and have learned to adjust to them just fine. Even in the summer we can live just fine (for a while) with one A/C running. With all due respect, you really don't have to have 50A all the time. - CA_TravelerExplorer IIIWe've been doing this long enough that we just adapt to whatever power is available. I added a second 20A circuit so that we can use 30+20A when available.
But the SW summer time and it's 50A or keep on trucking. :B - John___AngelaExplorer
Yah but that stuff all runs off the inverters. I have a dedicated separate 60 amp smart charger installed that I plug into a 15 amp supply, or garage plug, or whatevers handy in situations like that. Coach acts like its plugged into 30 amp service, charger and the battery bank does the rest. But yah I get what you are saying, for the average RVer you need to do a little power management if you are running 30 or 15 amp service. - obgrahamExplorerRun your Keurig, Washer, dryer, hair dryer, curler, and several TV's and pretty soon you're needing 50 amps!
- John___AngelaExplorerHmmm. I don't ever remember seeing a 50 amp service in Tunnel mountain. Having said that I can't imagine needing 50 amp for anything. For that matter I can;t image needing more than 15 amp service in that neck of the woods. Just get a 50 to 30 adapter and you will be fine.
- docjExplorerWe stayed at both Whistler's and Tunnel Mountain last July and had 30A sites at both. As someone else has already noted, we didn't need to use A/C once at either location so it really didn't matter. We had plenty of sunny days but I think the highest we ever saw while at Whistler's was ~75F. We thought it was amusing that our "neighbors" at the next site who were from Edmonton thought it was necessary to turn on the A/C that day because it was so hot! :B
- crabbin_cabinExplorer IIBring the various adapters and you can get by anywhere without 50 amp service - we hwve done it for years. Besides why, in Banff area do you think you will need 50 amp service. Hardly ever any need for air conditioners in the mountains.
- hedgeExploreryou can use the link below to check out the sites and see some pics of them. I did a quick look and didn't find any 50a in Tunnel mountain but I didn't check them all.
Reservation site - BaxtersparentsExplorerThis is all I could dig up on which sites has electric. I would have the map up
when making your reservation & ASK the person you're speaking to about which ones have 50 AMPS
https://reservation.pc.gc.ca/Jasper%2fWhistlersCampground%3fMap
This is another site I use quite often about actual reviews:
http://www.rvparkreviews.com/regions/Alberta/Jasper_National_Park.html
About Bucket List Trips
13,488 PostsLatest Activity: Sep 26, 2025
