Thank you moisheh !
The Mechanic and the Machine Shop were fully aware of the thickness issue and would not reinstall them unless the Discs were within tolerance!
This was a part of Our discussion during the initial inspection. Neither disc was badly scored although the right front one certainly wasn't smooth .
In Canada the Rotors would have been tossed into the scrap bin,along with the Pads and anything else that the mechanic could find fault with.
The days of repairing things is over NOB ! Now it is replace everything with a new or re manufactured part ,charge an extra 15% for Shop supplies that may include some Brake Clean Spray and a clean Shop Rag and turn the Fancy Work Order or Printout over to the Billing Department.
Oh and keep that Customer out of the Shop!
Here I was able to watch the entire process ! I didn't though because the Breakfast at Roosters was too good to pass up!
