Many miles of Interstate were built with concrete slabs which have tended to shift with use. Often one end tips down a bit, the other up. When a heavily loaded truck tire crosses from the up end of one slab to the next, it drops and puts further downward pressure on the next. The result is a sawtooth surface. If the period of that surface coincides with the RV suspension tuning the ride can be very rough.
On a different scale it's like the washboard that can develop with use on a gravel road. The click-clack of railways is also caused by the same thing - the move from loaded rail to an unloaded one.
States have been trying to fix this problem for decades.
The most effective, but expensive, fix is to tear up the road bed, and pour new slabs with some sort of ties to keep them in line. And with a heavier duty base. In the 1980s I drove Montana freeways where all traffic was on one side, while they rebuilt the other.
A more common fix is cut slots in the adjacent slabs, and install tie rods (dowels) to link the slabs. You want to keep them in line vertically, but still allow for horizontal motion (temperature expansion and contraction). I saw that being done on Illinois freeways in the 1980s. This still requires closing lanes for quite some time.
A quicker, but somewhat temporary fix, is to grind down the road surface to remove the steps, and lay down a layer of asphalt. Grinding and reapplying asphalt is relatively fast and cheap, and can be done without long term closures.
For smaller jumps, such as at bridge approaches, engineers have developed an injection fix - holes are drilled in the slab, and precise quantities of some sort of grout or polymer are injected, bringing slab(s) back into alignment.
I'm sure California engineers know about all these methods (and may have pioneered some), and used them where feasible, and funding allows.
The problems with Donner Pass mentioned in another I80 thread are different. There, apparently, truck traffic, especially with chains, has worn grooves in the pavement. These are probably ok if your wheels fit the grooves (as other trucks) but uncomfortable if one wheel is in a grove, and other rides in and out.
Maintenance like this is a big headache if traffic is heavy. The traffic wears the road faster, but also makes it harder to fix. If there aren't convenient detours, the work has to be done piecemeal, lane by lane, section by section, often at night to avoid disrupting traffic any more than necessary. Urban and mountain freeways tend to be worst.
PolyLevel dealers in CaliforniaFederal manual on dowel placement
WSdot on pavement patching and repair
