Sort By
- sljohnson1938ExplorerI would assume that a new trailer probably would have a cheap set of tires on it. maybe not, but as suggested to purchase a set of GOOD tires is not that much when you consider the cost of the trip. keep a couple of the other tires as back up in case you need them. I would take two tires as spares.
good luck.
on our Alaska trip last year (2016) I replaced all 6 tires on our truck.
not really sure if they needed it, but made me feel better. - colliehaulerExplorer III
TUCQUALA wrote:
I did not know what they came with. If they did come with Goodyear, I wouldn't worry about it.
OP's Creekside should have Goodyear ST D rated tires on it. It may have E range if option on trailer. ORV doesn't use the cheapest Chinese tires on their trailers. The Goodyears may be from China, or New Zealand, or the US. Never have had a Goodyear problem on 3 trailers. But you have to take care of pressures and inspections, like many don't!!! - mockturtleExplorer III agree with Nodaker. Except for a long construction section in the Yukon, the roads are overall as good--or sometimes better--than those down here. Some of the unpaved roads I took, like the Denali Highway and the Nabesna road, were pretty rough and I probably wouldn't take the Nabesna Rd without 4WD. The Denali Highway is doable but don't plan to go more than 10-15 mph if you want your tires to survive. Sharp rocks embedded in the dirt. The Taylor Highway has a lot of frost heaves. I had no tire issues and traveled more than 7K miles.
- NodakerExplorerMy 2015 36' 5th wheel came with 'Towmax' tires which don't have the best reputation. I decided to replace them this past summer before leaving for Alaska. I chose the Sailun 637's. I kept the original tires and sold them this fall after returning from Alaska. That way I was able to travel with the regular spare plus an unmounted spare Towmax. That ensured I wouldn't have to replace a tire in a remote place at a premium price.
I also used a tpms system for the 5er tires.
I was also nearing time to replace tires on my truck so I also carried one of the 'old' tires unmounted in addition to the spare.
Bottom line, my precautions ensured that I had NO tire issues on the trip! :)
We found the roads not much worse than the lower 48. A few more rough & longer construction zones and a few frost heave zones but not bad. The key is SLOW DOWN and relax. - PA12DRVRExplorerJust a suggestion or two from an Alaskan-local:
- I would suggest that for any given road type (i.e. divided highway, gravel road, chipseal road) that many of the roads in AK are slightly (slightly) worse than their L48 counterparts due to frost effects and (IMNSHO) lack of proper maintenance;
- Outside of the "Major cities" (ha, ha, but meaning Los Anchorage and Squarebanks), any given tire except the absolute most popular will be hard to find just due to minimal stocking.
- Similarly, wreckers and tire repair will be fewer and further between, although not non-existent.
I would suggest: a) having new-ish tires strictly due to the distance one travels from the L48 to Alaska; and b) having ideally two spares each for trailer and truck; although not unknown to blow two tires in quick succession (or possibly 4, don't ask me how I know), having a surplus spare in each size should allow one to get to a sizable burg with a tire shop that has (or can get) replacements or can do a fix. "Spare" btw means rim and tire.
Best way to prepare for tire trouble is to avoid it by driving at a reasonable (= slow) speed as needed. - TUCQUALAExplorerOP's Creekside should have Goodyear ST D rated tires on it. It may have E range if option on trailer. ORV doesn't use the cheapest Chinese tires on their trailers. The Goodyears may be from China, or New Zealand, or the US. Never have had a Goodyear problem on 3 trailers. But you have to take care of pressures and inspections, like many don't!!!
- colliehaulerExplorer IIII would probably replace mine if they are the cheapest Chinese tires available with the best one I could find. Tire trouble is no fun wherever you are, especially on a trip to Alaska. The cost of tires would be such a small expense compared to the cost of the trip.
- 3oaksExplorer
explorenorth wrote:
Obviously you are our out of touch with rural America in the lower 48 states. A lot of us still travel on "chipseal", crushed gravel and shale roads even down here.TenOC wrote:
The roads in AK are no different than the roads in the lower 48, but the distance between towns is much greater.
Many of the roads are different in that they use chipseal rather than asphalt. It's much coarser, and although it's not obvious on car/truck tires, on my motorcycle, I get FAR less mileage on tires on northern roads. - TUCQUALAExplorerTires should be good, our Timber Ridge has about 5000 miles and they are close to new, in my opinion. As stated above, keep an eye on the tires and pressures.
Consider taking a second spare tire and wheel like your orig spare,just in case!! Also, double check your present spare retaining nut on the bracket. Many are not the same size, and sometimes not the same thread, as the wheels on the ground!! Need to make sure that you have a wrench or socket for both sizes, if different, or change out to be the same as ground wheels!!
I'm sure you have aluminum wheels on the ground, and a steel spare. Double check the wheel nuts to make sure that they will work on the spare wheel. They should, but better to know now than just outside of Toad River!!!! - explorenorthExplorer
About Bucket List Trips
13,487 PostsLatest Activity: Jun 03, 2020
