docsouce's avatar
docsouce
Explorer II
Jul 24, 2018
Eastbound through Denver Co
I'll be hitting Denver around noon. I'm running on I70. How tough is this road through he city. I understand about unforseen situations, Is there a good route around he city or is it tolerable. We're going to camp in Strasburg Co tomorrow. We've been hanging around small towns, and the desert for 4 weeks and big city traffic will be a shock!!!!
  • We hit Denver at high noon. The usual big city traffic that moved along at about 45 mph. Smooth sailing. As always, thanks for the help.
    Also, that I70 between Denver and Glenwood Springs is certainly an interesting/beautiful/tricky stretch of road.
  • No worse than 128 or the Mass Pike any time of day. Relax and enjoy the sights.
    Let us Know how the Drive was - if you hit it at noon on Wednesday should be a breeze.
  • Use the traffic app WAZE. I70 usually isn't bad at noon. Usually. But there are always unforeseen circumstances, and WAZE will get you around them.
    Noon will be FIne - Let me give you a Map that will make the last bit out of the Mountains Special.
    Left hand exit #244 off I-70 to RT 6 follows Clear Creek through the Canyon with 6-7 tunnels - Just Beautiful then runs right into RT 58 that will run back into I-70 headed out of town.
    Map
    As with all big towns timing is everything.
    One more suggestion - try RT 36 all the way to Hannibal to get back East. Keeps you off the i's for a bit and just keeps getting Better - Little traffic and even fewer trucks. We always take it, going back to Maryland.
    Best of Luck,
  • X2. 70 should be reasonable that time of day barring accidents however there is some big construction east of i25. You might check cotrip.org just before you hit town and checkout the traffic cams. If really bad you could jump on i76 to i270 back to 70 bypassing the construction will cost a few miles but could be worth it time wise if the cameras aren’t looking good probably cost you 8-10 miles tops
  • There's no good way around Denver. Stay on I70 and get it over with.
