lazyboy's avatar
lazyboy
Florida to Arizona best route?
What is a good route from Florida to Arizona avoiding I 10 as much as possible? Towing 32 ft 5th wheel and not setting any speed record.
  • Go West........
    Hwy 84 to TX then Hwy 67 to Hwy 87 then Hwy 180 then I-10 on into AZ
    Hate traveling Interstates and we avoid them as much as possible.
    FTd for 7 yrs traveling secondary/back roads and had more height issues in Campgrounds then hwy/roadways
    Just pay attention and Look UP!
  • If you are just trying to AVOID Highway I-10, try above I-20 then are you trying to avoid all Highways as that would be a bit crazy avoiding Highways to State Roadways Try Maps.Google.com for backroads and watch trailer height under bridges. Burn a lot more fuel this way.
  • Which part of AZ? North or South? North you get on Hwy 287 near Dallas which runs you into north NM, you can take US 64 west from there which is a nice scenic route. Getting to the DFW area involves a lot of secondary TX, LA, MS and AL roads. In FL US98/19 will run you west. The TX ones generally aren't too bad but the others will lead you thru and endless set of small towns with 30 mph speed limits. Talking I-10 to US 45 near Mobile up to I-20 makes the most sense to me anyway. Once you are in TX on I-20 there are many secondary roads.
    South AZ, I'd take 98/19 to Pensacola then I-10 to Antonio TX you can then head south to the TX/MX border area and via US 90 (quite scenic) then US 54 up to south NM (Carlsbad in this area) and follow local to Las Cruces when you pretty much have to get on I-10 since there are few local east-west routes because of the Mogallon Rim I assume. Then maybe US 70 from Lordsburg NM. AZ has lots of routes from there.
  • Starting out where in Florida ?
    US 27/19 are good ways to go north from the west coast or central.
    Then just guessing from looking at a map, US 90 might be good for going west after that......part way.
