Kaz
Apr 15, 2016Explorer
Tom N wrote:
In MS S&T save your trip as a GPX file. For old Garmins use Garmin's MapSource software to load that .GPX file in to your Garmin GPS. For new Garmins us Garmin Ecpress.
Mapsource
Garmin Express
Right, but you may need to clean up the .gpx file. For example, when I do an export from S&T, the rtept entries often have "[time]Invalid DateTime-05:00[/time]" which makes MapSource choke. I just do a simple search and replace. FWIW, I also put each entry on a separate line just so it's easier to read.
Other than that kind of cleanup, the transfer process is seamless and easy.
Skip
On edit: I had to use brackets in lieu of the real symbols to get this message to post. Hopefully the code text is clear.
About Bucket List Trips
13,488 PostsLatest Activity: Sep 22, 2026
