- Dutch_12078Explorer III
silvercorvette wrote:
Dutch_12078 wrote:
PennDOT is currently saying that I-81 is closed until Monday, May 13th.THIS IS A PENNDOT TRAVEL ADVISORY. INTERSTATE 81 IS CURRENTLY CLOSED IN BOTH DIRECTIONS BETWEEN EXIT 70 AND EXIT 59, UNTIL MONDAY, MAY 13. MOTORISTS TRAVELING INTERSTATE 81 SOUTHBOUND SHOULD USE EXIT 70 TO INTERSTATE 83 SOUTHBOUND. MOTORISTS TRAVELING INTERSTATE 81 NORTHBOUND SHOULD USE EXIT 59 TO PA 581 EASTBOUND. MOTORISTS CAN EXPECT MAJOR DELAYS AND ARE ADVISED TO AVOID THE AREA, IF POSSIBLE.
www.511pa.com/AlertsAll
I am headed for NY via 81 on the 14 I'll check for updates, thanks for the heads up.
PennDOT has now revised the alert to say that I-81 will reopen on Tues, May 14th at the earliest. - silvercorvetteExplorer
I am headed for NY via 81 on the 14 I'll check for updates, thanks for the heads up. - jwlbalExplorerIt is unclear what will be closed indefinitely but the demolition is continuing around the clock as of tonight. There will be reduced lanes on 22/322 ramps as these bridges are being removed. I-81 will eventually reopen but it is a huge mess at the present time. The volume of traffic being detoured is causing monumental delays on the PA Turnpike and PA-581/I-83. There have also been numerous other accidents on these roads.
- johnwalkerpa1Explorer
ct1964ups wrote:
Bea PA wrote:
They have opened some ramps that were closed and you can get on the turnpike at several places toll free. Traffic is a real mess and backed up everywhere with folks looking for alternate routes. We are going to use Rt 15 to get to Hershey.
Can you go 83 to 581 and get around the problem ??
Yes, you can but.....you'll still see slow or stopped traffic and delays at certain times of the day. - J2Explorer
Yes I-81S to I-83S to 581 to I81S or 83S to 283S to Pa tp west to I-81
Stay away at rush hours - J2Explorerboth over passes that go over I-81 need removed before I-81 can be opened
- Dutch_12078Explorer IIIPennDOT is currently saying that I-81 is closed until Monday, May 13th.
www.511pa.com/AlertsAll - ct1964upsExplorer
Can you go 83 to 581 and get around the problem ?? - Bea_PAExplorerThey have opened some ramps that were closed and you can get on the turnpike at several places toll free. Traffic is a real mess and backed up everywhere with folks looking for alternate routes. We are going to use Rt 15 to get to Hershey.
- pa_travelerExplorerThat's going to be nasty,hope it can be fixed quickly ,but there not saying when yet.
About Bucket List Trips
13,488 PostsLatest Activity: Aug 08, 2016
