spindrift's avatar
spindrift
I80 and I70
Will be leaving for southeast WY in two weeks from Central Jersey. We had been planning to take the "southerly" route (I70) because I was on I80 two winters ago and it was a mess. Now I'm hearing that I70 is to be avoided like the plague. Apparently, the interstate between Indianapolis and Columbus is especially rough. Any thoughts? Thanks.
  • Interstate highways are generally a better option for ANY place you want to go if speed is important to you. If you want to actually SEE anything during the trip back roads are your best option. Main difference between 80 and 70 is the number of trucks you like traveling with. 80 is the major east west truck route from coast to coast (not that they are scarce on 70, just less of them.
    At ANY given time during warmer weather, either of those routes will be under construction an many places and in major cities that construction can be pretty much a constant thing but even then they are usually the most economic (in time and money) way to go.
  • I-80 in PA is fine - the only problem is it becomes the Ohio Turnpike and that means $$.
  • Ohio is fine, Indiana not so much. Parts of IL not great either, but once your cross the river the road is in fine shape all the way to Denver.
