- romoreExplorer IIStill has to be in metric here.
- Jebby14Explorer
DrewE wrote:
Aren't you glad that modern tires are sized using one metric measurement (the tread width), one imperial measurement (the wheel diameter), and one unitless quantity (the aspect ratio)? Otherwise, you'd have to change the tires when you change the air; putting metric air in inch tires would cause all sorts of problems.
Aspect ratio is not unitless its just that a ratio. its the sidewall height based on a percentage of the tires width. - Jebby14Explorerand minimum wage here in Ontario is roughly $427/h
- trigleyExplorer
zigzagrv wrote:
Also, metric air is not cheap. It takes several loonies to fill your tires.
Yes, and each of them is paid at least the minimum wage. - Artum_SnowbirdExplorerDo not rely on your cheap PSI tire pressure gauge when you cross into Canada. You will need to get one of our kilopascal gauges to be sure.
- hclarkExplorerMetric air is actually sold by the English Pound
- gboppExplorerDon't waste your money on metric air. Spend a little more and get the good stuff, Metric Nitrogen.
- DrewEExplorer IIAren't you glad that modern tires are sized using one metric measurement (the tread width), one imperial measurement (the wheel diameter), and one unitless quantity (the aspect ratio)? Otherwise, you'd have to change the tires when you change the air; putting metric air in inch tires would cause all sorts of problems.
- zigzagrvExplorerAlso, metric air is not cheap. It takes several loonies to fill your tires.
- almccExplorerYes, the air is metric here! The only countries in the world that don't have metric air are Myanmar, Liberia and the USA!
About Bucket List Trips
13,488 PostsLatest Activity: Sep 26, 2025
