Ed_White's avatar
Ed_White
Mexican Diesel Fuel/Sulfur Effects Update
Much to my distress I just learned here in the Southern Baja that the owner of a late model GM diesel pickup paid almost $3,000 to ship his truck back to the USA when it went into limp mode (5 mph) in Los Barriles. It is a 2013 and he experienced the typical signs of TEMPORARY sulfur poisoning of the emissions system. That is, engine light on, followed by DEF QUALITY POOR warning light, then progressive speed limitation.
The reason I'm distressed is because he didn't need to spend the $3,000 !!! These problems are COMPLETELY MANAGEABLE when you know what to do to force a regeneration. The regeneration cycle burns the sulfur compounds out of the system. I can only think that he was not computer literate so never located references to the extensive knowledge base about this issue on the net.
Anyway, if anyone knows of, or hears of, an owner of a late model (post 2007.5) diesel pickup truck having the above problem, PLEASE PUT THAT PERSON IN TOUCH WITH ME IMMEDIATELY at whitetmp@aol.com
Depending on the model year, I can provide the model appropriate information needed to completely manage the problem and NEVER go into limp mode.
Thankfully, the issue of excessive sulfur in Mexican diesel is almost over. Pemex announce last September that it had allocated funds to refurbish their refineries during 2015 so that ULSD (Ulta Low Sulfur Diesel) will be available across 60% of Mexico by mid-year and throughout Mexico by early 2016. Let's hope they stick to the promised timetable.
  • DIESEL FUEL IN MEXICO – AN UPDATE
    FOR 2007.5 - 2015 PICKUP OWNERS
    For those new to this topic, Mexican diesel fuel presently contains up to 500 ppm of sulfur, while the Ultra Low Sulfur Diesel (ULSD) sold in Canada and the USA is just 15 ppm. Unfortunately, the higher sulfur Mexican diesel can cause temporary “sulfur poisoning” of the emissions system for some pickup trucks with diesel particulate filters (DPF) and selective catalytic reducers (SCR). (DPFs were introduced in late 2007, SCRs were added by Ford and GM in 2011, and Dodge introduced SCRs in 2014). Your pickup truck has both DPF and SCR technology if you add Diesel Exhaust Fluid (DEF) to a separate on-board tank.
    THE GOOD NEWS
    Despite the potential for emissions system problems on DPF/SCR equipped pickups, laboratory testing prior to 2007 suggested that 2007.5 through 2010 model year diesels, whether Ford, GM, or Dodge, would tolerate well the higher sulfur Mexican diesel. This has indeed turned out to be the “real world” situation. There can be occasional bluish exhaust smoke during regeneration cycles, but no serious fault conditions are triggered. In addition, testing prior to the release of DPF equipped pickups confirmed that there would be no permanent damage to the emissions system, as long as higher sulfur fuels were not used for more than 40,000 continuous miles.
    For 2011 and 2012 model years, some owners have been experiencing occasional engine light illumination, and “DEF QUALITY POOR” warnings. Those warnings typically disappear, however, following a 15 minute high speed run, OR during subsequent heavy trailer towing, OR after the next regeneration. All of these situations usually raise exhaust gas temperatures high enough to purge sulfur compounds from the system.
    DEF QUALITY POOR warnings tend to occur a few weeks after a fifth wheel or other heavy trailer has been disconnected, and the truck is being driven around locally in Mexico. Lower exhaust temperatures while unloaded permit the buildup of sulfur compounds, reducing the efficiency of the emissions system until an error code is triggered. The Diesel Exhaust Fluid is NOT the culprit in these cases, even though that is the message displayed. It is simply a matter of the engine computer thinking that higher than expected NOX (oxides of nitrogen) in the exhaust is evidence that the DEF is not doing its job.
    THE “NOT-SO-GOOD” NEWS
    In 2013, Environmental Protection Agency monitoring requirements for NOX in the exhaust became much stricter. Monitoring is more frequent, and NOX must remain within a tighter tolerance level. In addition, regenerations to burn off the soot and sulfur compounds are less frequent. As a result, 2013 and later model year diesel pickups are more likely to register fault codes while in Mexico, and clearing the codes is more complex.
    Also for GM 2013 and later model years, the distance which can be travelled after a DEF fault is triggered, and before “limp mode” (maximum speed 4mph) is initiated, gets accelerated with time. This means that the available non-limp-mode miles often disappear more quickly than warranted by the distance travelled, creating a stressful experience for owners.
    Luckily, not every owner will experience such fault conditions, but when they happen, the key is to get the truck to do a regeneration as soon as possible. Once the emissions system is cleared of sulfur compounds by the heat of a regeneration cycle, the engine computer stops thinking that there is a problem with the DEF, and the fault condition disappears. It is critical that a regeneration be initiated well before limp mode occurs, because the vehicle must be driven at highway speeds for about 35 minutes during a regeneration.
    FORCING A REGENERATION CYCLE
    Unfortunately, there is no direct method for an owner to force a regeneration, but some pickup models have an indirect method based on EPA requirements that regenerations must occur approximately twice as often if there is a problem with the DPF pressure sensors. So, disconnecting the DPF pressure sensors can sometimes force a regeneration, provided that more than half the normal distance between regenerations has already been travelled.
    Typically, immediately after disconnecting the DPF pressure sensors, the driver will see a message that soot filter cleaning has started and to keep driving at highway speeds until it is finished. If half the normal distance between regenerations has not yet been travelled, it could be up to 200 hundred miles before a regeneration is triggered, but odds are, for a fault to have been triggered by excess sulfur buildup, it is likely that more than half the normal distance since the last regeneration has already been travelled
    Knowing how to unplug the DPF pressure sensors on 2013 and later model years will allow some owners to trigger a regeneration, which in turn purges the SCR of sulfur compounds, and clears the DEF warning. Detailed instructions are available for owners experiencing a fault condition, although it is more complicated when limp mode has already occurred.
    Hopefully, Pemex will stick to the timetable it announced in September of 2014 to upgrade its refineries in 2015 and to have ulsd diesel available across Mexico by early 2016. If that happens, an annual complication for many Snowbirds will be eliminated for good, Irrespective of the manufacturer of your pickup though, if it requires Diesel Exhaust Fluid, be sure to take at least 5 gallons with you into Mexico. The only confirmed source in Mexico at this time is Napa Auto Parts, which will special order DEF from the USA at around twice the normal price.
    Owners needing more specific information, or with a personal experience to share, can contact me at whitetmp@aol.com. Please note though that the information provided in this article, and to any owners who need assistance, is provided only in the interests of sharing of knowledge, and should not be interpreted as an endorsement or encouragement by the author for owners of 2007.5 and later pickup trucks to drive them into Mexico.
    Ted White
    January 6, 2015
  • Brian and Sue, you are correct, there is a lot of information about DPFs on the internet, but the data you have posted has nothing at all to do with the TEMPORARY sulfur poisoning that can occur when Mexican LSD is used while driving in Mexico. (LSD - Low Sulfur Diesel as compared to the ULTRA Low sulfur diesel (ULSD)in the USA)
    I think it could be safely stated that I am considered to be an EXPERT on this subject, not only because I have studied and reported on it at length since early 2007, but I also have contacts within the automotive emissions programming community of the Big Three, so I have access to information about sulfur effects that is not generally available to the public. In addition, I have access in Mexico to electronic equipment that can instruct affected vehicles to burn the sulfur out of the emissions system when required.
    In Mexico, the DPF (Diesel Particulate Filter) NEVER causes any significant problems, irrespective of whether it is fitted to a Dodge, a Ford, or a GM product. It is the SCR (Selective Catalytic Reducer) which suffers from sulfur poisoning serious enough to turn on the engine light and DEF warning. The SCR is responsible for reduction of NOX in 2013 and later vehicles which use Diesel Exhaust Fluid (urea) as part of their emissions system.
    The DPF clogging problems referenced in Brian Sue's post are almost exclusively associated with earlier model years (2007.5 through 2010) which had regeneration programming that failed to adequately deal with stop start driving, such as that done by airporter busses and local delivery vehicles. There was a problem in ensuring that exhaust temperatures were high enough, for long enough, to "light off" the carbon in the DPF. This was overcome in later model years by programming that ensures high enough exhaust temperatures during regeneration, even if the engine is only idling, and forces regeneration cycles to last for at least 30 minutes.
    Again though I want to point out that DPF clogging issues were extremely rare, and have nothing at all to do with the use of LSD fuel in Mexico.
    As for fault codes remaining permanently in the ECR (on board computer) of vehicles, all of the codes associated with the emissions system issues experienced in Mexico AUTOMATICALLY ERASE after a regeneration, because emissions monitoring returns to normal. Even if a fault code did not erase though, it has no meaning other than to record an incident. For example, if one of the codes associated with incorrect NOX levels (P20EE or P2BAD) was present when an owner visited a dealership at a later date it would be of no interest to a technician. The normal conclusion would simply be that a temporary condition triggered the code and there is no ongoing problem.
    I will post the text of an article on this subject in a separate post.
  • DPF
    The question of using Mexican diesel fuel in diesel powered vehicles built in 2007 or later comes up often on this forum. I am certainly no authority – we have a 2006 so this is not a concern of ours. Some say that many owners drive their newer trucks all over Mexico with no problem. Newer vehicles require ULSD which is 15ppm sulfur while older vehicles only require LSD which can contain UP TO 500ppm sulfur. Since I really know nothing about this I did some Googling and came up with some info and also more websites where more can be learned by anyone who is really interested. I have read somewhere that the vehicle ECM computer stores information about everything that happens with the engine and diagnostics equipment can read these computers – they will know if improper fuel is used and this could void the warranty. I sincerely wish all vehicles could be safely driven in Mexico and I encourage anyone with the proper equipment to visit Mexico – it is not my intent – now or ever – to discourage anyone from travel in Mexico. I have no other answers than what can be found below……Anyone can Google for lots more info……….
    http://en.wikipedia.org/wiki/Diesel_particulate_filter
    Wall-flow diesel particulate filters usually remove 85% or more of the soot, and under certain conditions can attain soot removal efficiencies approaching 100%. Some filters are single-use, intended for disposal and replacement once full of accumulated ash. Others are designed to burn off the accumulated particulate either passively through the use of a catalyst or by active means such as a fuel burner which heats the filter to soot combustion temperatures. This is accomplished by engine programming to run (when the filter is full) in a manner that elevates exhaust temperature or produces high amounts of NOx to oxidize the accumulated ash,[3] or through other methods. This is known as "filter regeneration". Cleaning is also required as part of periodic maintenance, and it must be done carefully to avoid damaging the filter. Failure of fuel injectors or turbochargers resulting in contamination of the filter with raw diesel or engine oil can also necessitate cleaning.[4] The regeneration process occurs at road speeds higher than can generally be attained on city streets; vehicles driven exclusively at low speeds in urban traffic can require periodic trips at higher speeds to clean out the DPF.[5] If the driver ignores the warning light and waits too long to operate the vehicle above 40 miles per hour (64 km/h), the DPF may not regenerate properly, and continued operation past that point may spoil the DPF completely so it must be replaced.[6] Some newer diesel engines, namely those installed in combination vehicles, can also perform what is called a Parked Regeneration, where the engine increases RPM to around 1400 while parked, to increase the temperature of the exhaust.
    http://towprofessional.com/2013/12/dont-get-clogged-up-diesel-particulate-filter . . . where they say in part . . .
    This is where the trouble begins. A clogged DPF filter can result in diesel soot backing up into the engine, causing damage to the VGT actuator, turbo, fuel injectors and EGR solenoid. Also, the unburned fuel injected into the exhaust system, as part of the regen cycle, can go into the crankcase contaminating the engine oil.
    And……….
    These DPF problems are so common that Dodge/Cummins owners have filed a class action lawsuit which has yet to be settled.
    Quick look on eBay . . . http://www.ebay.com/bhp/diesel-particulate-filter . . . I see Mercedes Sprinter DPF very special deal only $1,250 and a Cummins for only $1,864
    http://www.minutemantrucks.com/dpf-cleaning . . . cost of cleaning
    http://www.worktruckonline.com/channel/fuel-management/article/story/2008/01/what-fleet-managers-should-know-about-diesel-particulate-filters/page/2.aspx
    http://www.truckinginfo.com/article/story/2009/05/diesel-particulate-filters.aspx
    http://www.fleetserv.com/service/dpf-maintenance/understanding-diesel-particulate-filter-maintenance
    http://emissionsretrofit.com/products/diesel-particulate-filters
    More can be found online.
    ..or owner's manual literate.
