briansue's avatar
briansue
NEW ROAD AROUND GUADALAJARA
In no way do I claim this attempt at a drawing is even close to accurate. A new road appears to be in construction that will eventually loop all around Guadalajara. Those of you familiar with the area will get some idea of where it goes from the following rough map. It can be seen on Google Earth where most of the road can be seen if you look closely. The Google Earth Image Date is from February 2015 so about a year old. More has been accomplished since then. I don't know much more than that other than we have seen some of the construction going on as we drive other roads in this area. This will be a big help in the effort to avoid Guadalajara traffic.
  • Most of it is already there .... must just be widening and bypassing. It should be in the valley on the other side of the mountains from Chapala. See it?
  • You can see it under construction if you travel along the north shore of lake Chapala
