jaycocamprs
Mar 25, 2014Explorer
Chuck_thehammer wrote:
I have a 04 Ram 1500 V6.. 3.7 with a 5 speed manual transmission...
Clutch is the most likely weak link. Once you get rolling I think you will be all right. I doubt you will be able to use 5'th gear at all. Find a speed that you can run in 4'th that has decent RPM. I think that the steep hills will take 3'rd, and I would shift into 3'rd early enough that you get 3,500+ RPM. If you can hold that RPM good, climb the hill at that speed. If not drop to 2'nd and repeat. But I think that you should be able to pull the 6% grades with 3'rd. Watch out for real slow trucks, (heavy haul and oversize) the one that are doing 5-10 MPH. You don't want to stall out, and they have lower gears than you do.
About Bucket List Trips
13,488 PostsLatest Activity: Jul 25, 2025
