PNW_Steve
Aug 21, 2014Explorer
pianotuna wrote:
Hi Steve,
The inverter needs to be sized at 125% of the maximum. I can see no reason to not use the 2k pro watt since there is little difference in price between it and the next smaller model. It is a "throw away" unit so it is better to oversize than run a smaller unit on the edge of maximum.
Since it is a trailer, I would run the roof air for the last two hours of travel. I hate the heat.
I am with you on the heat. I spent 7 summers in the middle of the Mohave Desert. Fortunately the A/C in my 29' will drop the temp from 90F to mid 70s in about the time it takes me to make camp.
I ran the numbers on the scenario above except 25% duty cycle instead of 33%. Estimated run current goes from 1.08A (120v) to 1.39A. I wish I had access to actual locked rotor current and run current. That would give me more confidence in sizing the inverter.
About Bucket List Trips
13,488 PostsLatest Activity: Jul 25, 2025
