SteveWoz's avatar
SteveWoz
Trip Planning
I'm thinking of springing for the $39 for RV Trip Wizard. Any opinions on it and/or other trip planning preferences?
Thanks in advance.
  • RobWNY wrote:
    Steve, I plan my trip using RV Trip Wizard. I find locations along the way that I will need to get fuel based on what I've entered for MPG calculations. I also find campground stops along the way if it's a long trip. Then I use Google maps to get a satellite view of every stop so I know I can get in and out of the fueling places. Once I'm pretty certain I have everything entered and I'm happy with things, I use Google maps and re-trace what I've done in RV Trip Wizard. When I'm ready to go on the trip, I will text myself the Google map and route and use that as my navigation. I do have a stand alone trucker GPS (Garmin 760LMT) and I would use it except I can't get the saved RV Trip Wizard to transfer to the unit using Base Camp. It's not user friendly so I use my phone as I said. For me, RV Trip Wizard and Google maps is just the easiest solution. But as I said in my other post, these are just tools and not perfect. For instance, recently we went on a short trip and ran into a low bridge that RV Trip Wizard didn't have listed. I notified their support and they added it now but if I wasn't paying attention it could have been an ugly outcome.
    Thanks again! Are you saying that you don't believe a stand alone GPS is necessary? Does Google maps on a phone work even without cell service? Is it possible to transfer the Trip Wizard file to a GPS or are you just having technical difficulties? Correct me if I'm wrong, but you wouldn't need to cross check fueling facilities if you used the Garmin, right? I hope you don't mind all these questions.
  • Steve, I plan my trip using RV Trip Wizard. I find locations along the way that I will need to get fuel based on what I've entered for MPG calculations. I also find campground stops along the way if it's a long trip. Then I use Google maps to get a satellite view of every stop so I know I can get in and out of the fueling places. Once I'm pretty certain I have everything entered and I'm happy with things, I use Google maps and re-trace what I've done in RV Trip Wizard. When I'm ready to go on the trip, I will text myself the Google map and route and use that as my navigation. I do have a stand alone trucker GPS (Garmin 760LMT) and I would use it except I can't get the saved RV Trip Wizard to transfer to the unit using Base Camp. It's not user friendly so I use my phone as I said. For me, RV Trip Wizard and Google maps is just the easiest solution. But as I said in my other post, these are just tools and not perfect. For instance, recently we went on a short trip and ran into a low bridge that RV Trip Wizard didn't have listed. I notified their support and they added it now but if I wasn't paying attention it could have been an ugly outcome.
  • SteveWoz wrote:
    Edd505 wrote:
    RV Parky, GS Trip Planner, Google Maps, Streets & Trips if you can find it. First 3 are free 4 is no longer in production but can be found eBay or Craig's list.
    Thanks for the reply, (Ed?). Same question to you: Do you recommend a stand-alone GPS or do you use your phone for navigation?
    Steve
    Love Trip Wizard I have planned 5 trips with it each trip has 25+ stops-I am even using it to plan a trip to Germany this fall - yes it work in Europe too
    I have a Garmin RV GPS as we get to areas with no cell service
    Steve
  • RobWNY wrote:
    I have and use RV Trip Wizard. It's a good program and worth the money. With that said, it's not perfect. Use it as just one of the tools you use to plan a trip and you'll be fine.
    Thanks for that info, Rob(?).
    Could I also ask, do you recommend a stand-alone GPS or do you use your phone for navigation?
  • RV Parky, GS Trip Planner, Google Maps, Streets & Trips if you can find it. First 3 are free 4 is no longer in production but can be found eBay or Craig's list.
  • I have and use RV Trip Wizard. It's a good program and worth the money. With that said, it's not perfect. Use it as just one of the tools you use to plan a trip and you'll be fine.
