Jayco1c's avatar
Jayco1c
Would it be safe to pull a 35ft 5th wheel on UT-12?
  • We pulled a 34' fifth-wheel over Utah 12 and found it to be one of our favorite routes ever. This is a photo of the section that many find daunting. I did not experience any anxiety and would gladly follow this route again:
  • thought for a moment you were talking about the Moki dugway. :)
    bumpy
  • Yes -- no problem. I have seen big rigs on that road. Just make sure your passenger has taken a tranquilizer. ;)
  • JoeH's avatar
    JoeH
    Explorer III
    We drove it in our MH pulling a toad. We are 65' long. It does keep the driver busy watching the road, shifting to keep the temps in check. Very pretty scenery.
  • We drove this very scenic road a few years ago - it was awesome.
    We taped the entire trip on our dash cam so the driver could actually see some of the scenery afterwards. That seemed like a good idea, but it does not do it justice - you don't get the real depth perception but it was fun to re-live the drive somewhat.
    Take your time and be very cautious - it really is worth the drive.
  • If you are a flat lander, it can be quite intimidating. But it is doable if your truck is up to the task both for pulling up the grades and holding things in check on the down slopes. As mentioned, some sections are quite steep although they were not overly long. The scenery is beautiful but the driver may not have much chance to admire it as it is a demanding drive. We did it this summer but probably would not tow it again.
  • Depends on driver and what truck is being used to tow that 35' 5v
    Well maintained 2 lane very scenic drive
    We did it....3500 longbed/34' 5vr
  • We pulled a 34 ft fiver up Hwy 12 several times. My one suggestion, when you stop let the engine cool down before shutting it off. We got overheated alarms when we stopped at the scenic pull out at the top. Of course this assumes your truck is up to the job.
