valhalla360
Jul 03, 2023Navigator
Kept in mind if you go with a lower btu unit, it will run more.
So if a 15k btu runs 25% of the time a 5k btu will run 75% of the time...net result is the same number of Amp hours used.
While it's possible, it gets expensive compared to just breaking out the generator. Those that jump thru the hoops usually live with limited use.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
