enblethen
Apr 15, 2017Nomad
Do not confuse the 120 volt neutral and ground. There are different.
The green or bare wire in the 120 volt system should be connected to the rig's frame as a safety ground.
The white wire in the 120 volt system is the neutral. It should not be connected to the frame or DC system.
Look at some of the 12 volt DC lights. The shell of the lamp socket should be the ground. Check color of the wire.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
