time2roll
Oct 25, 2015Nomad
Batteries added to the rear of the axle will reduce the tongue weight.
Are you going full solar or will you have some sort of generator?
Inverter... my preference is separate components. Inverter - Converter - Transfer switch that can be replaced separately if something fails.
Subpanel is very convenient if you have space and access. I went with multiple transfer switches, one for each circuit powered.
With 4x GC2 I would put you in the 500 watt solar zone. 2x ~250w 24v panels in series feeding a Morningstar TS-MPPT-30 would be my starting point.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
