https://www.digikey.com/product-detail/en/signal-transformer/DU-7.5/DU-7.5-ND/1984857","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"118","kudosSumWeight":0,"repliesCount":0,"postTime":"2019-06-03T19:28:30.000-07:00","lastPublishTime":"2019-06-03T19:28:30.000-07:00","metrics":{"__typename":"MessageMetrics","views":1348},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:RVTalk/community:feyqc97479board:DIYMaintenance/message:3123686/message:3123701","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"readOnly":false,"editFrozen":false,"body@stringLength":"277","rawBody":"You need something like this:
https://www.digikey.com/product-detail/en/signal-transformer/DU-7.5/DU-7.5-ND/1984857","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:3123701_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"customFields":[]},"User:user:252791":{"__typename":"User","id":"user:252791","uid":252791,"login":"theoldwizard1","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2010-09-07T08:13:14.000-07:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-7.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:41"},"entityType":"USER","eventPath":"community:feyqc97479/user:252791"},"ModerationData:moderation_data:3123700":{"__typename":"ModerationData","id":"moderation_data:3123700","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:3123700":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:252791"},"id":"message:3123700","revisionNum":1,"uid":3123700,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:DIYMaintenance"},"parent":{"__ref":"ForumTopicMessage:message:3123686"},"conversation":{"__ref":"Conversation:conversation:3123686"},"subject":"Re: 240V from 120V generator","moderationData":{"__ref":"ModerationData:moderation_data:3123700"},"body":"
THIS (step up transformer) IS THE CORRECT ANSWER, BUT THERE ARE SOME ISSUES !
Step one Have a generator inlet installed on the house and have wired it to a generator interlock in the breaker panel. NOT a transfer switch. Less expensive and it allow you select at the time of the outage which circuits get power.
Step two
DownTheAvenue wrote: You can feed both 120 volt legs of your house by jumping the one hot leg over to both legs off the house. You will not have 240 volts to power things like the stove, dryer, A/C, but both legs of the house power will be charged with 120 volts.
More specifically, the voltage between the two legs will be ZERO !
Step Three Size the transformer referenced at the beginning for your well pump. My SWAG is 3000W
Step four Have an electrician wire a 240V DPDT relay (the coil voltage must be 240V) so that when you DO have 240V the pump receives power . When you DO NOT have 240V (power outage) the 120V runs through the transformer to the well pump.
I would add an additional 240V relay \"upstream\" from the transformer, wired so that the transformer does NOT receive power when 240V is available.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2019-06-03T19:21:46.000-07:00","lastPublishTime":"2019-06-03T19:21:46.000-07:00","metrics":{"__typename":"MessageMetrics","views":1347},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:RVTalk/community:feyqc97479board:DIYMaintenance/message:3123686/message:3123700","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"readOnly":false,"editFrozen":false,"body@stringLength":"1814","rawBody":"
Step two
I would add an additional 240V relay \"upstream\" from the transformer, wired so that the transformer does NOT receive power when 240V is available.","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:3123700_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"customFields":[]},"User:user:273971":{"__typename":"User","id":"user:273971","uid":273971,"login":"KD4UPL","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2008-03-16T18:18:04.000-07:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-7.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"entityType":"USER","eventPath":"community:feyqc97479/user:273971"},"ModerationData:moderation_data:3123699":{"__typename":"ModerationData","id":"moderation_data:3123699","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:3123699":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:273971"},"id":"message:3123699","revisionNum":1,"uid":3123699,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:DIYMaintenance"},"parent":{"__ref":"ForumTopicMessage:message:3123686"},"conversation":{"__ref":"Conversation:conversation:3123686"},"subject":"Re: 240V from 120V generator","moderationData":{"__ref":"ModerationData:moderation_data:3123699"},"body":"You can absolutely use your 120v generator and have 240v. What you are looking for is called an autotransformer, sometimes shortened to autoformer. One I would recommend is made by Outback Power, the PSX-240. I'm sure there are others. To answer your question about phase angle, the 2 hot legs of a 240/120v split phase service are 180 degrees out of phase. By using the PSX-240 and a PROPER TRANSFER SWITCH you can have 240v available in your panel form your 120v RV generator. As anyone with a deep well pump knows, often have 240v to run the well pump is one of the most important loads a generator might be needed for. The suggestion of feeding both legs of the panel the same phase is not a good one if your house has any multi-wire branch circuits. These can be identified by a cable containing a red wire in addition to the black, white, and bare ground. Supply both the black and the red with 120v from the same leg of a generator can cause the neutral wire to carry excessive current leading to overheating.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2019-06-03T18:36:10.000-07:00","lastPublishTime":"2019-06-03T18:36:10.000-07:00","metrics":{"__typename":"MessageMetrics","views":1351},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:RVTalk/community:feyqc97479board:DIYMaintenance/message:3123686/message:3123699","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"readOnly":false,"editFrozen":false,"body@stringLength":"1037","rawBody":"You can absolutely use your 120v generator and have 240v. What you are looking for is called an autotransformer, sometimes shortened to autoformer. One I would recommend is made by Outback Power, the PSX-240. I'm sure there are others. To answer your question about phase angle, the 2 hot legs of a 240/120v split phase service are 180 degrees out of phase. By using the PSX-240 and a PROPER TRANSFER SWITCH you can have 240v available in your panel form your 120v RV generator. As anyone with a deep well pump knows, often have 240v to run the well pump is one of the most important loads a generator might be needed for. The suggestion of feeding both legs of the panel the same phase is not a good one if your house has any multi-wire branch circuits. These can be identified by a cable containing a red wire in addition to the black, white, and bare ground. Supply both the black and the red with 120v from the same leg of a generator can cause the neutral wire to carry excessive current leading to overheating.","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:3123699_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"customFields":[]},"User:user:46207":{"__typename":"User","id":"user:46207","uid":46207,"login":"NRALIFR","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2005-11-26T23:11:36.000-08:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-4.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"entityType":"USER","eventPath":"community:feyqc97479/user:46207"},"ModerationData:moderation_data:3123698":{"__typename":"ModerationData","id":"moderation_data:3123698","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:3123698":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:46207"},"id":"message:3123698","revisionNum":1,"uid":3123698,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:DIYMaintenance"},"parent":{"__ref":"ForumTopicMessage:message:3123686"},"conversation":{"__ref":"Conversation:conversation:3123686"},"subject":"Re: 240V from 120V generator","moderationData":{"__ref":"ModerationData:moderation_data:3123698"},"body":"Generac home standby generators in a sound deadening enclosure with ATS is available from most big home centers and are reasonably priced. They can run on either natural gas or propane by simply sliding a fuel selector. I would install one of those before I’d mess with the gen set in your RV.
I’ve had a 10K NG unit installed on my house for over 10 years, and it has been a godsend. I’m not powering any 240 volt circuits with mine, but could if needed. I have 16 critical 120 volt circuits powered by the ATS. It powers up the gen and switches automatically after a power outage, then switches back to utility power when it comes back. The gen does a test run once a week on its own. It’s run as long as 5 days straight after a storm knocked our power out.
Propane and NG never go stale like liquid fuels.
:):)","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2019-06-03T14:47:57.000-07:00","lastPublishTime":"2019-06-03T14:47:57.000-07:00","metrics":{"__typename":"MessageMetrics","views":1348},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:RVTalk/community:feyqc97479board:DIYMaintenance/message:3123686/message:3123698","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"readOnly":false,"editFrozen":false,"body@stringLength":"849","rawBody":"Generac home standby generators in a sound deadening enclosure with ATS is available from most big home centers and are reasonably priced. They can run on either natural gas or propane by simply sliding a fuel selector. I would install one of those before I’d mess with the gen set in your RV.
:):)","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:3123698_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"customFields":[]},"ModerationData:moderation_data:3123697":{"__typename":"ModerationData","id":"moderation_data:3123697","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:3123697":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:374904"},"id":"message:3123697","revisionNum":1,"uid":3123697,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:DIYMaintenance"},"parent":{"__ref":"ForumTopicMessage:message:3123686"},"conversation":{"__ref":"Conversation:conversation:3123686"},"subject":"Re: 240V from 120V generator","moderationData":{"__ref":"ModerationData:moderation_data:3123697"},"body":"
Ivylog wrote: Probably easier and not any more expensive to buy a 4K generator that puts out 240V.
It would be but a generator is useless without fuel and I don't want to keep a bunch of extra gasoline that I rarely use around the house. I always put the motorhome away with 70 gallons of diesel available to the genset. Plus, that diesel is a lot quieter than most inexpensive generators. Actually, I already own a 5K gasoline unit but keeping it ready is a challenge.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2019-06-03T14:11:57.000-07:00","lastPublishTime":"2019-06-03T14:11:57.000-07:00","metrics":{"__typename":"MessageMetrics","views":358},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:RVTalk/community:feyqc97479board:DIYMaintenance/message:3123686/message:3123697","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"readOnly":false,"editFrozen":false,"body@stringLength":"513","rawBody":"
It would be but a generator is useless without fuel and I don't want to keep a bunch of extra gasoline that I rarely use around the house. I always put the motorhome away with 70 gallons of diesel available to the genset. Plus, that diesel is a lot quieter than most inexpensive generators. Actually, I already own a 5K gasoline unit but keeping it ready is a challenge.","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:3123697_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}}},"Rank:rank:39":{"__typename":"Rank","id":"rank:39","position":29,"name":"Nomad","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:108257":{"__typename":"User","id":"user:108257","uid":108257,"login":"time2roll","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2005-03-21T19:03:16.000-08:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-5.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:39"},"entityType":"USER","eventPath":"community:feyqc97479/user:108257"},"ModerationData:moderation_data:3123696":{"__typename":"ModerationData","id":"moderation_data:3123696","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:3123696":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:108257"},"id":"message:3123696","revisionNum":1,"uid":3123696,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:DIYMaintenance"},"parent":{"__ref":"ForumTopicMessage:message:3123686"},"conversation":{"__ref":"Conversation:conversation:3123686"},"subject":"Re: 240V from 120V generator","moderationData":{"__ref":"ModerationData:moderation_data:3123696"},"body":"6kw $1,300
Might have to be dedicated to just the pump. No neutral. Probably plenty to create split phase at higher cost.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"126","kudosSumWeight":0,"repliesCount":0,"postTime":"2019-06-03T13:24:58.000-07:00","lastPublishTime":"2019-06-03T13:24:58.000-07:00","metrics":{"__typename":"MessageMetrics","views":225},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:RVTalk/community:feyqc97479board:DIYMaintenance/message:3123686/message:3123696","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"readOnly":false,"editFrozen":false,"body@stringLength":"383","rawBody":"6kw $1,300
Might have to be dedicated to just the pump. No neutral. Probably plenty to create split phase at higher cost.","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:3123696_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}}},"User:user:332758":{"__typename":"User","id":"user:332758","uid":332758,"login":"Ivylog","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2004-06-30T11:56:50.000-07:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-11.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:40"},"entityType":"USER","eventPath":"community:feyqc97479/user:332758"},"ModerationData:moderation_data:3123695":{"__typename":"ModerationData","id":"moderation_data:3123695","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:3123695":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:332758"},"id":"message:3123695","revisionNum":1,"uid":3123695,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:DIYMaintenance"},"parent":{"__ref":"ForumTopicMessage:message:3123686"},"conversation":{"__ref":"Conversation:conversation:3123686"},"subject":"Re: 240V from 120V generator","moderationData":{"__ref":"ModerationData:moderation_data:3123695"},"body":"Probably easier and not any more expensive to buy a 4K generator that puts out 240V.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"84","kudosSumWeight":0,"repliesCount":0,"postTime":"2019-06-03T12:04:46.000-07:00","lastPublishTime":"2019-06-03T12:04:46.000-07:00","metrics":{"__typename":"MessageMetrics","views":225},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:RVTalk/community:feyqc97479board:DIYMaintenance/message:3123686/message:3123695","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"readOnly":false,"editFrozen":false,"body@stringLength":"84","rawBody":"Probably easier and not any more expensive to buy a 4K generator that puts out 240V.","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:3123695_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}}},"ModerationData:moderation_data:3123694":{"__typename":"ModerationData","id":"moderation_data:3123694","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:3123694":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:374904"},"id":"message:3123694","revisionNum":1,"uid":3123694,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:DIYMaintenance"},"parent":{"__ref":"ForumTopicMessage:message:3123686"},"conversation":{"__ref":"Conversation:conversation:3123686"},"subject":"Re: 240V from 120V generator","moderationData":{"__ref":"ModerationData:moderation_data:3123694"},"body":"
time2roll wrote: What do you have that is 240 volts and critical? I would thing the fridge a few lights and a few outlets would be fine in an emergency. Furnace should run on 120 power. Retreat to the RV if you need air conditioning or to cook. +1 to get an electrician to look at it.
AC, furnace and well pump. I don't have any built in fossil fuel heat. Giving out of water would be the most painful.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2019-06-03T09:56:47.000-07:00","lastPublishTime":"2019-06-03T09:56:47.000-07:00","metrics":{"__typename":"MessageMetrics","views":226},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:RVTalk/community:feyqc97479board:DIYMaintenance/message:3123686/message:3123694","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"readOnly":false,"editFrozen":false,"body@stringLength":"449","rawBody":"
AC, furnace and well pump. I don't have any built in fossil fuel heat. Giving out of water would be the most painful.","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:3123694_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}}},"ModerationData:moderation_data:3123693":{"__typename":"ModerationData","id":"moderation_data:3123693","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:3123693":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:108257"},"id":"message:3123693","revisionNum":1,"uid":3123693,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:DIYMaintenance"},"parent":{"__ref":"ForumTopicMessage:message:3123686"},"conversation":{"__ref":"Conversation:conversation:3123686"},"subject":"Re: 240V from 120V generator","moderationData":{"__ref":"ModerationData:moderation_data:3123693"},"body":"What do you have that is 240 volts and critical? I would thing the fridge a few lights and a few outlets would be fine in an emergency. Furnace should run on 120 power. Retreat to the RV if you need air conditioning or to cook. +1 to get an electrician to look at it.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"203","kudosSumWeight":0,"repliesCount":0,"postTime":"2019-06-03T08:10:34.000-07:00","lastPublishTime":"2019-06-03T08:10:34.000-07:00","metrics":{"__typename":"MessageMetrics","views":227},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"category:RVTalk/community:feyqc97479board:DIYMaintenance/message:3123686/message:3123693","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"customFields":[],"readOnly":false,"editFrozen":false,"body@stringLength":"271","rawBody":"What do you have that is 240 volts and critical? I would thing the fridge a few lights and a few outlets would be fine in an emergency. Furnace should run on 120 power. Retreat to the RV if you need air conditioning or to cook. +1 to get an electrician to look at it.","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:3123693_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}}},"User:user:18321":{"__typename":"User","id":"user:18321","uid":18321,"login":"w4phj","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2001-09-13T11:26:13.000-07:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-6.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"entityType":"USER","eventPath":"community:feyqc97479/user:18321"},"ModerationData:moderation_data:3123692":{"__typename":"ModerationData","id":"moderation_data:3123692","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:3123692":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:18321"},"id":"message:3123692","revisionNum":1,"uid":3123692,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:DIYMaintenance"},"parent":{"__ref":"ForumTopicMessage:message:3123686"},"conversation":{"__ref":"Conversation:conversation:3123686"},"subject":"Re: 240V from 120V generator","moderationData":{"__ref":"ModerationData:moderation_data:3123692"},"body":"
X2","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:3123692_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"customFields":[]},"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarDropdownToggle-1741694506000","value":{"ariaLabelClosed":"Press the down arrow to open the menu"},"localOverride":false},"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/EscalatedMessageBanner-1741694506000","value":{"escalationMessage":"Escalated to Salesforce by {username} on {date}","viewDetails":"View Details","modalTitle":"Case Details","escalatedBy":"Escalated by: ","escalatedOn":"Escalated on: ","caseNumber":"Case Number: ","status":"Status: ","lastUpdateDate":"Last Update: ","automaticEscalation":"automatic escalation","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserLink-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserLink-1741694506000","value":{"authorName":"View Profile: {author}","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserRank-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserRank-1741694506000","value":{"rankName":"{rankName}","userRank":"Author rank {rankName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageTime-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageTime-1741694506000","value":{"postTime":"Published: {time}","lastPublishTime":"Last Update: {time}","conversation.lastPostingActivityTime":"Last posting activity time: {time}","conversation.lastPostTime":"Last post time: {time}","moderationData.rejectTime":"Rejected time: {time}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolvedBadge-1741694506000","value":{"solved":"Solved"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSubject-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSubject-1741694506000","value":{"noSubject":"(no subject)"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBody-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBody-1741694506000","value":{"showMessageBody":"Show More","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} No Longer Available","mentionsErrorMessage":"The {mentionsType} you are trying to view has been removed from the community.","videoProcessing":"Video is being processed. Please try again in a few minutes.","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageCustomFields-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageCustomFields-1741694506000","value":{"CustomField.default.label":"Value of {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyButton-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyButton-1741694506000","value":{"repliesCount":"{count}","title":"Reply","title@board:BLOG@message:root":"Comment","title@board:TKB@message:root":"Comment","title@board:IDEA@message:root":"Comment","title@board:OCCASION@message:root":"Comment"},"localOverride":false},"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/AcceptedSolutionButton-1741694506000","value":{"accept":"Mark as Solution","accepted":"Marked as Solution","errorHeader":"Error!","errorAdd":"There was an error marking as solution.","errorRemove":"There was an error unmarking as solution.","solved":"Solved","topicAlreadySolvedErrorTitle":"Solution Already Exists","topicAlreadySolvedErrorDesc":"Refresh the browser to view the existing solution"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Pager/PagerLoadMorePreviousNextLinkable-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Pager/PagerLoadMorePreviousNextLinkable-1741694506000","value":{"loadMore":"Show More"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeView/NodeViewCard-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeView/NodeViewCard-1741694506000","value":{"title":"{nodeTitle} ","creationDate":"Created: {creationDate}","ownedBy":"Owned by: {owners}{text}","showOwnerListText":", and {ownersCount} more","unreadCount":"{count} unread","nodeViewDrawerBtn":"Node view drawer for {place}","drawerActionTooltip":"Show category children"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewInline-1741694506000","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonymous","place":"Place {bylineBoard}","gotoParent":"Go to parent {name}"},"localOverride":false},"Revision:revision:3123698_1":{"__typename":"Revision","id":"revision:3123698_1","lastEditTime":"2019-06-03T14:47:57.000-07:00"},"Revision:revision:3123700_1":{"__typename":"Revision","id":"revision:3123700_1","lastEditTime":"2019-06-03T19:21:46.000-07:00"},"Revision:revision:3123695_1":{"__typename":"Revision","id":"revision:3123695_1","lastEditTime":"2019-06-03T12:04:46.000-07:00"},"Revision:revision:3123699_1":{"__typename":"Revision","id":"revision:3123699_1","lastEditTime":"2019-06-03T18:36:10.000-07:00"},"Revision:revision:3123701_1":{"__typename":"Revision","id":"revision:3123701_1","lastEditTime":"2019-06-03T19:28:30.000-07:00"},"Revision:revision:3123696_1":{"__typename":"Revision","id":"revision:3123696_1","lastEditTime":"2019-06-03T13:24:58.000-07:00"},"Revision:revision:3123692_1":{"__typename":"Revision","id":"revision:3123692_1","lastEditTime":"2019-06-03T07:29:51.000-07:00"},"Revision:revision:3123693_1":{"__typename":"Revision","id":"revision:3123693_1","lastEditTime":"2019-06-03T08:10:34.000-07:00"},"Revision:revision:3123694_1":{"__typename":"Revision","id":"revision:3123694_1","lastEditTime":"2019-06-03T09:56:47.000-07:00"},"Revision:revision:3123697_1":{"__typename":"Revision","id":"revision:3123697_1","lastEditTime":"2019-06-03T14:11:57.000-07:00"},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1741694506000","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1741694506000","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/nodes/NodeDescription-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/nodes/NodeDescription-1741694506000","value":{"description":"{description}"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeTopicsCount-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeTopicsCount-1741694506000","value":{"topicCount":"{count}","topicCountWithNeutralLabel@board:OCCASION":"{count, plural, one{# Event} other{# Events}}","topicCountWithNeutralLabel":"{count, plural, one{# Post} other{# Posts}}","topicCount@board:FORUM":"{count, plural, one{# Post} other{# Posts}}","topicCount@board:BLOG":"{count, plural, one{# Post} other{# Posts}}","topicCount@board:CONTEST":"{count, plural, one{# Entry} other{# Entries}}","topicCount@board:GROUP":"{count, plural, one{# Topic} other{# Topics}}","topicCount@board:IDEA":"{count, plural, one{# Idea} other{# Ideas}}","topicCount@board:QANDA":"{count, plural, one{# Question} other{# Questions}}","topicCount@board:TKB":"{count, plural, one{# Article} other{# Articles}}","topicCount@board:OCCASION":"{count, plural, one{# Event} other{# Events}}","title":"{count, plural,one {Post} other{Posts}}"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeLatestActivityTime-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLatestActivityTime-1741694506000","value":{"title":"Latest Activity: {latestActivityTime}","updatedAt":"Updated {latestActivityTime}","noActivity":"No activity yet"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"after":"MjUuMnwyLjF8aXwxMHwzOTowfGludCwzMTIzNzExLDMxMjM3MDI","boardId":"diymaintenance","messageSubject":"240v-from-120v-generator","messageId":"3123686"},"buildId":"G6LFdF6Y8sb5g8rZyM3sC","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","openTelemetryClientEnabled":false,"openTelemetryConfigName":"campingworld","openTelemetryServiceVersion":"25.2.0","openTelemetryUniverse":"prod","openTelemetryCollector":"http://localhost:4318","openTelemetryRouteChangeAllowedTime":"5000","apolloDevToolsEnabled":false,"inboxMuteWipFeatureEnabled":false},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["./components/seo/QAPageSchema/QAPageSchema.tsx","./components/community/Navbar/NavbarWidget.tsx","./components/community/Breadcrumb/BreadcrumbWidget.tsx","./components/messages/TopicWithThreadedReplyListWidget/TopicWithThreadedReplyListWidget.tsx","./components/nodes/NodeActionButtonWidget/NodeActionButtonWidget.tsx","./components/nodes/NodeInformationWidget/NodeInformationWidget.tsx","./components/messages/RelatedContentWidget/RelatedContentWidget.tsx","./components/customComponent/CustomComponent/CustomComponent.tsx","./components/community/FooterWidget/FooterWidget.tsx","./components/messages/MessageView/MessageViewStandard/MessageViewStandard.tsx","./components/messages/ThreadedReplyList/ThreadedReplyList.tsx","./components/community/FooterWidgetHelpLink/FooterWidgetHelpLink.tsx","./components/community/KhorosLogo/KhorosLogo.tsx","../shared/client/components/common/List/UnstyledList/UnstyledList.tsx","./components/messages/MessageView/MessageView.tsx","../shared/client/components/common/Pager/PagerLoadMorePreviousNextLinkable/PagerLoadMorePreviousNextLinkable.tsx","./components/nodes/NodeView/NodeView.tsx","./components/nodes/NodeView/NodeViewCard/NodeViewCard.tsx","./components/messages/MessageView/MessageViewInline/MessageViewInline.tsx","./components/customComponent/CustomComponentContent/TemplateContent.tsx"],"appGip":true,"scriptLoader":[]}
