westend wrote:
The absence of a 50 amp receptacle at a campground pedestal is not that common anymore and, if encountered, can be dealt with easily using an adaptor.
You must be staying only in high-end CGs...:B The NEC (art. 551) only requires 20% of pedestals to have 50 amp while 30 amps are required at 70% of them.
The NEC requirements are min. and anyone can upgrade from that, but it does add a lot of cost to the initial wiring. The NEC is way behind on keeping up with all the RVs these days with 50 amp services. Same on how wiring size is calculated to each pedestal.
Many of the CGs we stay at are older ones and have maybe 10% (?) or less 50 amps, which I'm guessing is because the NEC requirements decades ago required even fewer 50 amp pedestals.
