fpresto
Feb 03, 2017Explorer
I have to agree with bemmerphile1. What you have here is a solution to a nonexistent problem. Thousands of RVs work fine without any additions. If you are getting odors from the black tank then you have a plumbing problem that should be addressed OR you are flushing with the vent fan running. In that case you will pull odors from the tank.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
