wmoses's avatar
wmoses
5-2 Day Programmable Honeywell Thermostat Upgrade
My 2014 Flagstaff 27RLWS travel trailer was outfitted from the factory with an analog Coleman-Mach thermostat. We found that it did not control the temperature swings above and below the set-point to our satisfaction. The RV warmed up too much before the AC kicked in and in the cooler weather, the temps This means that a thermostat upgrade was in my future.
See writeup here.
  • Playtime II wrote:
    On the Honeywell mod, remove the faceplate and then jump the 12v(+)terminal to the AC (or Heat)terminal Thus bypassing the thermostat's thermometer until the interior gets within the operating temp of the thermostat.
    A 3" piece of 18ga works fine.
    You can always buy a RV themostat and avoid all of this.
    And this clears the "EE" message in the display? I searched for a more elegant way to reset the thermostat but so far could not find any info.
    I'd rather do the reset than buy an RV thermostat at this time.
  • You do not need to reset/clear the Honeywell. It just displays EE (since it does not recognize the extreme temperature, it does not know to heat or to cool so it won't send 12v to the system needed (AC/Heat)). Once the interior reaches a temp within the spec, it will display the temp.
  • I put a non-programable Honeywell in my camper and it's been a great mod. I put the low/hi switch in the camper wall just above the thermostat. It won't get bumped, and I don't plan to pull the thermostat when I sell the camper.
  • I put a Honeywell 5-2 in our 5er as well. It is the same one we have at home, so I didn't need to learn a new thermostat.
    I love the fact that our camper will warm up in the morning before we get out of bed.
    I just wired the AC to run at high speed all the time, because if I want AC, I want AC!
