LangsRV2
Apr 14, 2013Explorer
westend wrote:
If you can attach a strip of wood or two into the back of the cabinets, parallel with the top and bottom surfaces of the cabinets, it will allow for attachment into the studs when you're done with the walls.
Thanks! That sounds like a perfect plan. We didn't want to take the siding off just to install the cabinets. The old cabinets were fastened from the top and side but only into the luan. I'm kind of surprised they were as sturdy as they were. Fastening into the studs seems like a much stronger long term solution.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
