LangsRV2
Dec 07, 2013Explorer
Roof is all done. So we put the insulation back to the front. We debated if we should use foam board instead of bat insulation. But decided to reuse the insulation instead of spending more $ on foam board. Also cutting to fit all the nooks and crannies then caulking the edges sounded like more work than we wanted at this point. We decided that since we are mostly fair weather campers it is probably not critical. I don't plan on camping in the dead of winter anytime soon, OK or ever! Hat's off to you die hard campers out there braving sub zero temps. We did add heavier insulation to the roof than was originally there. Not sure if it will make a difference but we did it anyway.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
