boogie_4wheel
Apr 20, 2018Explorer
The only thing I can suggest is when working with box tubing (or vehicle frames, ect) is to weld a flag on the bolt. Then you can fish the bolt/washer combo into the hole and tighten it without the bolt spinning because the flag will rotate and make contact with the tube. I use any piece of scrap flatbar tacked to the bolt head.
Good work!
Good work!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
