TNGW1500SE's avatar
TNGW1500SE
A/C drain issue
My A/C likes to drain water down onto the awning. I'm thinking of adding a "gutter" on the roof to direct the water to either side of the awning. What I'm considering, is using some metal that is used in drop ceilings. The peices that they use to go around the walls are "L" shaped. I'm thinking I could epoxy them to the roof above the awning. Thoughts?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: May 25, 2022
