Hornnumb2's avatar
Hornnumb2
Add led indicator
Is there an easy way to add an led indicator to the outside cover of the fridge, so I can tell its still running on propane. The fridge is on the rear of my trailer but when traveling on propane it would be nice to have a led to know if its still burner on those road side stops.
  • I installed LED's to indicate:
    AC power available
    AC element getting power
    DC power available
    External fans on
    Gas valve energized.
    I needed to increase the resistance on the AC indicators & a blocking diode to prevent inverse voltage breakdown.
    I also installed a multi-sensor temperature reader just inside the door. So if the gas valve LED happens to be dark, I can open the door to confirm the temperature.
    It works a treat
  • We also have a wireless temp indicator from LaCrosse.
    You could also get a cheap wireless backup camera and point it at the control panel inside.
  • DrewE's avatar
    DrewE
    Explorer III
    Do be aware that the burner not operating does not necessarily mean it has blown out. It cycles on and off as needed to maintain the proper temperature, just as a residential fridge's compressor does.
  • I towed out last TT all over the country and it's fridge was at the very back of the trailer.
    It never blew out, not even once. I've also had them on the sides with the same success.
    Frankly these fridges work so good that I just never worry about what they're doing. (Just like the one at home)
    My suggestion is that you do the same.
    Good luck,
    Scott
  • Thanks for the comments, seems like an easy mod. I should have all parts already. My fridge is on the back wall so I haven't had any problem with it blowing out but it would just be piece of mind to see the led lit.
  • My propane fridge burners have blown out once since 1978. You don’t need one.
  • If flame blows out and it does NOT relight/prove lit doesn't fridge indicate such on upper display panel...Either a 'Check' light or a 'X' ?
    You could run a wire from gas valve solenoid (power side) to an LED.
    Whenever solenoid had DC Power the LED would be ON
    Solenoid would only have DC Voltage when circuit board energized gas valve
  • To me, the way I understand question... the purpose of wanting a LED light is to see if burner is or is not on, while traveling on propane?
    I went a slightly different route because I wanted to know what our actual frig/freezer temps were when traveling. And not in love with any open flame while traveling but that is talk for another debate.
    What has worked out great for us is a wireless temp gauge. Didn't think the "wireless" thing would work going down the road but is works fine. Fridge at rear of trailer is about 42 feet from tow vehicle dash to fridge/freezer. In this link below be sure to read the comments and decide for yourself. Lots of reviews.
    When we got ours I couldn't get it to work. You have to buy high priced batteries that will work in freezer and we can't hear the so called "warning peeps" over road and engine noise. But wife just takes a glance every so often. Beyond those problems, which we could care less about, the gauge has worked out great for several years. And we have found out that we don't even need to have fridge/freezer on when traveling on most days in our 2012 trailer. But in our older 2003 class C only good for about 4 hours. Also found out If outside temps are going to be above 75 then we just turn down temps colder before going to bed the night before. If you do get one of these... directions are not the greatest, just go step by step.
    Batteries must be "lithium batteries (not included)" in the sensors, regular batteries won't work because of low temps. Especaily the freezer. Friends saw how good ours work and ordered one. Theirs didn't work right from the beginning. They returned it and no questions asked and replacement was within a week.
    https://www.amazon.com/AcuRite-00986A2-Refrigerator-Wireless-Thermometer/dp/B004QJVU78
    The elec knowledge is great on this forum... I had help installing a LED so I could tell if I remembered to shut off water pump or not by just looking in my driver side mirror.
    You might have other reasons for a LED light, but by the time and money and hassle your going to have invested putting in a LED...you might want to consider a wireless gauge.
    Also at home when our elec goes out after a storm I put sensors in house fridge/freezer, so I know when and if I need to run extension cord from genny in RV to house stuff.
  • DrewE's avatar
    DrewE
    Explorer III
    What make and model of fridge do you have? Do you want the LED to illuminate when the burner is actually burning, or when the fridge is on in gas mode?
    If the fridge has electronic controls it should be possible to add an LED without too much difficulty. For seeing when the burner is burning, wiring the LED (with appropriate series dropping resistor) in parallel with the gas solenoid ought to work. I doubt the extra 10-20 mA would cause any problems for the controls; but just the same, I disclaim any responsibility should it somehow cause problems.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
