bob213
Mar 23, 2014Explorer
bluka43 wrote:bob213 wrote:
Do you just remove the wires from the outside switch and run from there?
Well, no...the rocker switch is still there and in the on position. I just don't use it any more. First I cut the hole for the switch box and then I dropped a 14/3 wire down to the circuit breaker panel. (I was fortunate that the panel is located in the bathroom cabinet and back to back of the wall where the switch is) I removed the wire hot wire from the circuit breaker and replaced it with the black wire of the 14/3 for the hot to the switch. The red wire in the 14/3 is wire nutted in the panel to the wire that came off the breaker, and the white wire of the 14/3 as a neutral for the light on the switch when in the on position.
Thank you bluka43. Sounds like my next project!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Dec 04, 2025
