havasu's avatar
havasu
Adding a 3rd AC
As we tend to spend summers in the Desert due to work commitments, keeping cool has become a priority for us. I resealed the roof and gave it several coats of elastomeric, I have interior and exterior blinds for the windshield etc and have serviced the roof ACs. However when it starts to get north of 105F everything struggles to keep up.
I contemplated installing a 3rd AC unit on the roof, using the existing hole for the kitchen fantastic fan, but couldn't find an easy way to run cables without tearing out half the ceiling.
As we had already pulled out the old couch and installed a large chair and ottoman, I had space in the front of the slideout for a portable ac. After a lot of research I found a dual hose portable 11000 btu AC with a very low noise level
Whynter 11,000 BTU Portable Air Conditioner ARC-110WD from www.sylvane.com with free shipping and a memorial day sale - total $430.
I discovered that you have to use a dual hose system in an RV so that it sucks air in from outside to cool the condenser and then exhausts it - a single hose system takes air from the room to do that and that sucks in hot air from outside defeating the purpose of it!
Below are some photos of the install - it was very easy - I did buy a 4" hole cutter from Home Depot to make a neater job. Everything was sealed with Dicor and there are covers that fit on the outside vents when not being used. It can also be removed from the RV in winter although there are some that act as a heater too (not this one).
The first time I tested it, we noticed it was so much quieter than the roof air even on full blast and whereas the roof air had problems getting below 87 at 4pm, by switching this on as well, we could 'dial a temperature' - it got down to 72F within an hour and DW is looking for her coat!
Well worth the money!! Bring it on Desert summer!
  • This looks good. I think I would add exterior dryer vents over the openings on the outside. I believe it would look more factory that way.
  • Not really. When the unit isn't being used, there are solid caps that clip on to cover them. Either in the winter or when travelling.
  • Nice way to work around a problem. Do you have any concern with critters getting into the unit thru the in/out grate openings?
  • Yes, I was a little nervous but I did what my Dad told me - measure twice, cut once :) I also invested in a 4" hole cutter designed for can lights - made short work of it but when the guide bit went through the fiberglass, I went outside and cut from outside in.
    It runs off the normal 15a outlet - I just have to remind DW not to run the tea kettle at the same time as it pops the circuit breaker. I added a battery backup unit for her computer (iMac) so that it doesn't cause any problems if she forgets :)
  • What is your electric source? Did you use an existing outlet? 9.5 amps seems easy enough to manage.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
