champdog's avatar
champdog
Adding a 3rd mobile panel
Thanks for all the replies in my other post. I stated I was going to purchase the 120w suitcase kit. Well after alot of reading and learning from all here on this site Ive changed direction. I DID purchase 2 100w panels and a 40amp mppt charge controller. I now want to set it all up so I can add a third mobile panel. I have a breaker between the panels and the controller. My thinking is to wire an sae pigtail from the breaker where the panel wires are bolted to it, and run the sae pigtail into one of the outside compartments so I can plug my mobile panel into that. Any thoughts?
  • champdog wrote:
    THANKS! Ill look into those connectors, they look awsome. I thought Id pick up a semi flex panel because their lite. Ive seen pvc frames or legs, good idea for sure. We boondock quite a bit in the trees. Thought moveable panel would provide extra when the California forest is blocking some of the 200w on the roof. Ive seen some posts with a fuse between the panels and the cc and some without. I thought a shut off switch would be a good idea so just bought a manual reset circuit breaker. tying a pigtail into the pv wires before the cc seemed like its the same as if I bought another set of mc4 y connectors.Thanks again
    Good plan except for the flex panel choice. I would think that a smaller, rigid module would be a better choice, less chance of module failure and easier deployment. The only trade-off is weight and there is not enough to worry about with these sized modules.
  • THANKS! Ill look into those connectors, they look awsome. I thought Id pick up a semi flex panel because their lite. Ive seen pvc frames or legs, good idea for sure. We boondock quite a bit in the trees. Thought moveable panel would provide extra when the California forest is blocking some of the 200w on the roof. Ive seen some posts with a fuse between the panels and the cc and some without. I thought a shut off switch would be a good idea so just bought a manual reset circuit breaker. tying a pigtail into the pv wires before the cc seemed like its the same as if I bought another set of mc4 y connectors.Thanks again
  • Almot's avatar
    Almot
    Explorer III
    I dislike portable panels for being portable - with all that this entails - but I hear people are happy with Anderson Powerpole connectors for this application. SAE doesn't look serious for anything more than 5W trickle charger.
    Now you can go to Home Depot and get a piece of PVC pipe for panel legs. Don't remember the reasons for not getting that 3rd panel up on the roof - hopefully they are valid.
    Btw, no breaker is necessary between panels and controller.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,396 PostsLatest Activity: Nov 18, 2025
