AlwaysDreaming's avatar
Jan 12, 2018
Adding a Roof Vent Fan in a vent where there is none
2017 Thor Chateau/Four Winds 22B 22FT Class C
I would like to put a high velocity vent Fans in the 2 roof vents which currently do not a have a fan.
The bathroom roof vent does have a dinky 1 speed fan. Upgrading the Bathroom is no problem because the 12 Volt power is there.
My question(s) are:
The electrical schematic shows wiring to these vents, does anybody know if the roof vents are pre-wired? The Thor Electrical Schematic shows wiring to the vents.
Has anybody tried to modify the 12V wiring in the roof of a Thor RV?
There is a 12V light near (30 inches) the vent which is not on a switch (push button on the light), how would I splice into it? How do these lights detach?
Is there special tools or techniques to snake wires in the RV ceilings? I assume there is a “space” between the outside roof and the inside roof? Do you have to take the inside roof off to do the wiring?
Thanks
  • most vents do not come pre wired. all you have to do is snake a wire to the closest light. just be sure you wire it properly or you will need to have the light on in order for the fan to operate. it is very simple and most anyone can do it
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,368 PostsLatest Activity: May 03, 2025
