poorboy's avatar
poorboy
adding fireplace
thinking about adding electric fireplace in cabinet below the tv. I only have 30 amp not 50 amp.
my questions are, has anyone done this, and are their places in the fuse box to add this? my brother has a factory built-in fireplace, but trips the breaker if he uses the fireplace and microwave at the same time. I have almost average intelligence, so I am comfortable doing the carpentry and electric install myself, but would like input from anybody that has done this.
  • thanks for the input folks, the tapping in to the a/c sounds like a good idea. don't know if there is an outlet inside the cabinet or not.
  • How many amps will the electric fire place draw, and what size breaker feeds the AC?
    Dusty
  • The fireplaces draw a max of 1500 watts. Some have a HI-LOW switch that cuts them back to 800 watts on low.
    After trying to teach my wife to be sure the water heater was off before using the microwave on our last motorhome, I wired in a switch that either powered on or the other. Problem solved. They both used the same breaker with that modification.
  • My TT is 30A and came with the fireplace option. I've been driveway camping the past couple weeks and run the fireplace at night. We've still had some nights where temps drop into the high 30's and the furnace comes on occasionally to assist the fireplace but not as much as it would without. I can see by my EMS-HW30C that amp draw varies between 10-16A depending on other devices I have turned on. I am plugged into a 30A pedestal. If the OP's trailer is connected to a 15 or 20A pedestal he may trip a breaker at times but I have not on my 30A dedicated circuit.
    Unless they recently upgraded the EMSHW30C, don't rely much on the EMS current readout. The EMSHW30C current reading is notoriously inaccurate. The mfg will even admit it. It can read high, low or near accurate on the same load. I've seen mine read as low as <20A when drawing near 30A and as high as 35A when the known draws is 15A.
  • DFord wrote:
    Another BTW: RVs aren't covered by the NEC. You'd never get away using one of those cheapo RV receptacles in your house - and their production shouldn't be allowed. They're horrible!
    RVs are most definitely covered by the NEC - ARTICLE 551- RECREATIONAL VEHICLES AND RECREATIONAL VEHICLE PARK covers all electrical requirements for RVs as well as RV parks. Here is an older free version of the 2005 edition NEC
    There is nothing wrong with the SCD (self-contained device) in RVs (also used in mobile homes). The problem is those not knowing how to work with them and how to correctly terminate the wires on them, including the factories. Under UL standard 498 they must meet very stringent testing and every bit as stringent as testing for residential type side/back-wired recepts.
  • I installed 3 permanent recessed electric heaters totaling 2,000 watts. I used a current sensing relay for demand control so that when the main 30 amp supply current gets above a preset adjustable level, the heaters are automatically disconnected. We can run coffee maker, toaster, MW and other loads and never trip a 30 amp breaker.
    The limitation on breaker spaces in RVs doesn't exactly make sense. I installed a recessed vacuum unit and needed a dedicated 15 amp breaker and for the heaters, a 20 amp breaker. The only way around it is using tandem breakers which I have zero issue with doing.
    For a dedicated heater of any kind, I'd install a separate dedicated receptacle for it wired directly back to the panel.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 18, 2025
