Fischtravel's avatar
Fischtravel
Aerodynamics with build
Hello! We are building a rough RV onto our trailer bed and wonder if you can help with some advice on what shape the front (by the hitch) should be? We’ll be towing behind a Honda Pilot and we’re thinking of merely pitching the roof and stabilizing the wood joints with metal brackets. Driving out west-could get windy!! Thanks!
  • DrewE wrote:
    If you've seen the trapezoidal pyramid folding structures on some semi trailers, that is why they're there. You can safely bet the trucking companies would not install them without their saving enough fuel to make them pay over time.
    And you’d lose that bet.
    The reason those clunky pieces of junk are there is because the government requires them and other devices on truck fleets above a certain size.
  • Gjac's avatar
    Gjac
    Explorer III
    I don't think aerodynamics will make much difference in MPG because the tow vehicle is in front of the trailer and the square back of the tow vehicle would create a fair amount of turbulence anyway. I would built it to maximize space and other features you want and not worry about what ever small gains in MPG that you could get from maximizing the aerodynamic design.
  • Thank you. I think we’re gonna try a trapezoid shape. And thank you for the extra tips of weight distribution hitch and sway bars. I’ll post pics when we start next week!!
  • DrewE wrote:
    If by aerodynamics you're meaning mainly in terms of air resistance when towing, as opposed to other considerations like stability in sidewinds, then pay at least as much attention to the back as to the front as a lot of the drag comes from there. A rounded front and a long pointy back, like a teardrop, is about the best overall form. Of course a tapering back cuts into the usable space inside quite a bit.
    Not a trailer,but fine example of aerodynamics,,wish someone built such RV should get pretty decent mpg..
    https://goo.gl/images/4hJcwt
  • DrewE's avatar
    DrewE
    Explorer III
  • Thank you all for your responses!! The pilot can tow 3500pounds and the trailer is 12 feet long. I believe it’s 6 feet across. We were thinking of marking essentially a shed or A frame with pitches roof for aerodynamics but this is a first for us.
  • The simplest thing in my opinion would be to run the front wall flat until you reach the roofline of the Pilot and then 45 back to the final roof height.
  • How much weight can a Honda Pilot tow behind it?
    What size length & weight is the trailer bed?
  • There is a few comments here you might want to look at carefully. Honda Pilot towing
    No matter what, it always feels more comfortable with something that is 80% of the limit rather than at the limit, or stuffed even over the limit.
    Lot's to consider with a cross country trip loaded with many treasured things.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
