CJM1973
Jun 30, 2020Explorer
pianotuna wrote:
Pretty much all lead acid jars need to be fully charged. It is a bit harder to "recover" an AGM that has been left partially charged.
It will also be important to wire the batteries in a balanced manner. For an odd number of batteries only method #3 from the link below will work.
correctly interconnecting multiple twelve volt batteries
Thanks for the advice. I did read that AGM's are temperamental with subpar charging parameters. This is why I'm trying to identify the ideal charging characteristics of these AGMs. I think I'll stay with the battery manufacturer's recommendations.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
