pianotuna
Jun 30, 2020Nomad III
Hi 2oldman,
I have but 256 watts of solar. My battery banks are in two 278 amp-hour banks. While in storage on Dec 21 about 17 amp-hours are pumped back into the battery bank.
The OP has only 300 amp-hours--so if he is a "week ender" 200 watts may yield a solar harvest of 800 watt-hours or about 58 amp-hours per (perfect) solar day.
Assuming 5 days between trips, there should be no problem returning the bank to fully charged. The biggest issue is getting to a high enough voltage.
AGM's wish to be "woken up", in general--so that is why I suggested crowding the higher side of the recommended cycling voltage, given the barely big enough solar wattage. I've allowed for non tilting fixed installation in the math above.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
