jjrbus's avatar
jjrbus
Aluminum span tale?
I have a 94 Toyota with a sagging roof near the AC. I want to run an aluminum angle from side to side on the roof to remove the sag. I have seen this done with 3" steel angle.
I would prefer to use aluminum angle. I have 1 1/4" .125 aluminum angle and it has too much flex or give.
Anyone know of tables or charts that will give the deflection of aluminum angle or span tables for it?
  • I haven't played around with this but it might do what you want:
    deflection calc
    The correct engineering term for what you want is 'deflection'
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,405 PostsLatest Activity: Apr 21, 2026
