time2roll
Oct 27, 2014Nomad
Heat only should be a slam dunk. Hunter will explain heat only connection.
Or consider a heat only thermostat. Honeywell
Also consider a radiator style electric heater to even out the heat some and reduce furnace run time.
I would be inclined to get an Atwood digital replacement although it will probably cost more.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 16, 2026
