HanSolo's avatar
HanSolo
Any Experience With Insulation?
I have recently bought a Ford E450 Box Truck which I will be converting into an RV. I have some work ahead of me!
My first job will be to insulate, and I am thinking about using closed cell Polyurethane foam for the walls. For both cost and space reasons, I would like to put no more foam than necessary into the walls.
From surfing the web, it seems like 1 to 2 inches might be sufficient. Does anyone have experience with this type of insulation? How much of a difference do you think 2 inches will make as opposed to 1?
Also, does anyone know if it is safe to spray the foam directly against the metal outsides of the box?
  • Hi,
    I'd go for more than two inches. Spray foam--if done on the outside--what will you cover it with?
