- mikestockExplorer
RedRocket204 wrote:
down home wrote:
Only way I see feasible now are the metal pole frames with the material stretched over them. I can't think of the name or brands but failing a hard side garage it would seem a better alternative, depending on price.
I have not done this... but you could easily make a frame out of 3/4-1" PVC pipe to where it is wider, by a few inches over each side and end. Just make sure the pipe touching the roof is only the pipe and not connector pieces. Should be smooth /rounded enough to not cause issues.
I used 1-1/4" PVC, a few years back, to make a tent for my pontoon boat. When the daytime temperatures started hitting the 90's that PVC started sagging and formed into permanent bows. If you use PVC you will need to keep the unsupported lengths short. - babockExplorerMark all the sharp spots with white bar soap and bring to a canvas shop to have them sew in vinyl reinforcements. Mark on the outside and they will install on the inside.
I will be making my cover this January. I will be using Sunbrella and it will fit like a glove so no flapping at all. All wear points will have vinyl sewn in.
I make boat covers so this will be an easy job compared to them. It will be on the heavy side but should last at least 10 years. - GoostoffExplorerIn all my years I have never once even considered a cover. My father-in-law made the mistake one year, against my better judgment, of putting a big blue tarp over his trailer. Yep rub marks all over the place come spring as well as mold everywhere. He now just leaves it out in the weather like we do. Give it a bath in the spring and hook up and go.
Why are you packing it up? There is still 2 full months of good weather and maybe even more. We always go untill the mast weekend in October. Thats when our favorite campground closes for the year. - RedRocket204Explorer
I have not done this... but you could easily make a frame out of 3/4-1" PVC pipe to where it is wider, by a few inches over each side and end. Just make sure the pipe touching the roof is only the pipe and not connector pieces. Should be smooth /rounded enough to not cause issues. - down_homeExplorer IIOur cover made of the latest and greatest material still let moisture in. Sunbrella, I think. W padded corners wit thick old towels, a mistake, Green growth developed.
Wind was a big buga bo. It go under and up the sides billowing and stretching the material. Had to tighten the buckles underneath every little bit.
Newer ones have blow out panels, on sides to stop wind from as much damage.
Swimming noodles does sound good if there was a way to hold them on corners or perhaps a similar material in a sheet form.
My thoughts over time, is perhaps someway to tent the cover over the top and away from the corners. It would be super for cooling air circulation and keeping rubbing from happening on corners etc.
Only way I see feasible now are the metal pole frames with the material stretched over them. I can't think of the name or brands but ailing a hard side garage it would seem a better alternative, depending on price. - trainman6899Explorer
SoundGuy wrote:
feel your pain but gotta cover up in California weather especially summer, covers only last about three years no matter we try,pain in ... to put on but if ya don't weather destroys them, need to research all manufacturers for a soft inside lining so movement from wind will not rub off finish and it will,good lucksmcrea wrote:
In the past we have tried all sorts of things to 'blunt' the corners and sharp edges to that the cover doesn't tear. We've used plastic balls to foam. All are a pin to install
Does anyone have any cheap and useful ideas on what to use?
3 covers over 10 yrs, no rips or deterioration at all. I use foam pipe wrap over the gutter extensions and scrap pieces of Reflectix over all sharp corners, both held in place with super sticky Duct tape. Even easier though is indoor storage, as I did last winter. :W - mike2wheelsExplorerI use pool noodles over pokey things like the CB antenna. I use a big cloth bag over the top of the ladder.
- BmachExplorer IIPool noodles work for me.
- allen8106Explorer
smcrea wrote:
It's time to install our cover after our last trip.
Thanks!
Sure, stop using the cover.
I personally never liked them. We had one for our TT and the cover burnished the paint from blowing in the wind.
Will never use one again. - SoundGuyExplorer
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
