falconman
Apr 21, 2014Explorer
I had two yamaha tri fuel generators that I used primarily on LP. You will need a tee to connect both units to the trailer but I don't think one tank would vaporize fast enough to supply them both at high speed. If you have an auto switchover regulator on the trailer it would allow only one tank at a time to flow and might not be sufficient. I ran one at a time off the low pressure port with no issues, when running two I used a separate bottle for each.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
