Dr_Quick
Jul 26, 2015Explorer II
Years ago for the "Conversion Vans", they would put in an auxiliary unit to cool the rear of the van. I had a Ford 150 van that I installed a rear unit in it. Ran off same compressor as the in dash air. I mainly consisted of putting "T" fittings in the supply and return lines for the AC and running hoses to the rear of the van. I installed the unit under the rear seat and ran ducts to four locations.
I found one Web Site for you for installing Heat AC to a van. https://www.discountvantruck.com/rvvanrearairconditioners/rvvanconversionrearac.htm
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
