RoyB
Jun 10, 2013Explorer III
I like this distribution network - this would be worth the effort for me...
Roy Ken
NOTE: Actually I have already run 3/4-inch FLEX PVC conduit down the inside of one frame across the rear axle and back up to the fron running along the other frame... Shown in BLUE here... This was to protect my 12VDC wiring from being drug off when back off the beaten roads in the underbrush on my trailer. I added the BRAKE runs inside the the conduit already but didnt do any beefing up of it...
Would be pretty easy to install some outside two cond 10-gauge boat wires to the brake magnets... Might have to install one more PVC junction box... I like the idea of running the GROUND wiring as well. Mine is only running the POSITIVE wire from the 7-way Brake junction Box... Ground is frame ground.
GDETRAILER - My POPUP only has two BRAKE MAGNETS so my setting is 5-6 on my brake controller - plenty of adj room. With four brake magnets I can see where it would help more...
Roy Ken
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
