mapguy
Jun 18, 2013Explorer
spike99 wrote:
For all my boat, utility and RV trailers, I always remove their factory sequential "inside axle tube" wiring and replace with safer / much better STAR design using thicker 10 gauge wiring. IMO, this should be minimum factory build on all trailers. Perhaps one day it will be. Is there a difference? YES. If doing axle re-position or other suspension maintenance, I'd convert to STAR design at same time. It's well worth it..
Factory default (before): - click here -
After:
Did the same thing on my 30' fifthwheel toyhauler. Night and day difference in braking ability after it was done. Before mod - could barely skid tires on gravel with brake controller on high boost and high gain. After mod - no need for high boost or gain settings plus brakes work very well. The icing on the cake was the MaxBrake controller.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
