kfp673's avatar
kfp673
Explorer II
Jul 17, 2020
Anyone use Quick connect for water hose?
As the title says, I am interested in the idea of leaving a quick connect on the water hose for our travel trailer. We have a small plastic door that has a plastic connector which is again threaded to another connector in the camper. Sorry for the vague terms. I believe what is mounted from factory is 1/2" male to 3/4" female, and that 3/4" female is what the hose connects to. 1- I would like to replace that factory adaptor with a metal one (although the rest of the system is plastic anyway so not sure it matters) and 2- I'd like to leave a threaded quick connect on the camper and on the hose. Because this connection is recessed, it's often difficult to get the hose tight enough to avoid leaking and even spraying out. A quick connect would lave that portion connected and make it easy. Anyway, I see these all over Amazon. Is anyone using them for RV's? and if so any suggestions? Thanks!
  • kfp673: Sorry I don't have any links. I completed. my project after numerous runs to different rv parts stores. Sorry.
  • From my experience if you get the brass ones you want the one 's with the rubber washer. The Harbor freight one's will start leaking over time if they are just brass to brass.
  • ^^X2 Get the ones with the rubber o-rings. A light coating of silicone grease will keep the o-rings sealing well. Used QDs a lot when we used to take many shorter trips each year. Not so much anymore as we either boondock or stay at our winter location for 6 months.
  • I have QDs on everything. Just easier to hook up and then break down later. Fresh water hose, connect the ends when stored to keep critters out. I also have a water filter that is used occasionally, QDs make it easier to connect however we need at the time. But use the brass ones with o-rings. I carry a couble of spare sets, the ends occasionally get damaged and are hard to use.
  • I added quick connect garden hose fittings to my low point drains. I can connect an outdoor sink for outside hot and cold water cleaning or an on demand water heater in lieu of the onboard water heater or a city water in through the cold water low point.
    There is a small plastic 90° garden hose elbow quick connect available. It might work for you but hasn't for me on the city water inlet for closing the hatch after disconnecting. I bought them at one of my local trailer dealers. It was only the male hose thd x male garden hose quick connect fitting. Camping World has them as a set. Hose saver with quick connect.
  • I use them. However with low pressure if not aligned they may leak. I have some older ones that have tighter tolerances.
    Amazon has a variety but I haven't
    tried any of them except the ones that look the same as those from CW.
  • I use these on all my hoses....They are leak free and very secure.
    Banjo connector --> https://barndoorag.com/search-results/?search_query_adv=garden+hose+banjo
    Housted
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Jan 20, 2025
